New Engine Advice
Old Oct 15, 2014 | 11:07 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Vary load and rpms.
Don't baby it.
Don't prolong idle or too much steady rpm's.
Don't take it to redline for 4-500 miles.
Change the oil & filter at 500 miles.
By 750 miles you should be good to beat it like a cheating wife.
Old Oct 15, 2014 | 12:55 PM
fordboy97's Avatar
fordboy97
Originally Posted by ArdWrknTrk
Vary load and rpms.
Don't baby it.
Haha, thanks for that. I'd like to run synthetic oil in this engine. Any good brands you would suggest using?
Tanner
Old Oct 15, 2014 | 01:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I would run a break in oil for the first ( two) oil change especially.
I use Rotella T6 synthetic in my 460 and I like it.
Old Oct 15, 2014 | 04:58 PM
Ddaybc's Avatar
Ddaybc
Just pull the dizzy and use a 1/4" (5/16 for 351 & big block) deep socket and extension (taped together!) in a drill.
You will never turn the engine over by the crank enough to get oil to the rockers.
I have a cool set of 1/4" hex to square drive socket adapters that allow me to do this with my battery impact driver.
X2^ but don't forget to TAPE the socket and extension together!!!!!!
Old Oct 15, 2014 | 09:32 PM
fordboy97's Avatar
fordboy97
Do they sell the break in oil at part stores? I've never seen any.
Tanner
fordboy97's Avatar
fordboy97
Oh I'd hate to drop the socket into the distributor hole!
Tanner
Old Oct 15, 2014 | 09:41 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
Pick up an old dist at the JY and use the shaft to prime the pump. A lot easier and no risk of loosing the socket.
Old Oct 15, 2014 | 09:55 PM
eakermeld's Avatar
eakermeld
Tanner
Yes they do. Lucas, Comp Cams, Royal Purple are just a few.
Old Oct 15, 2014 | 11:53 PM
fordboy97's Avatar
fordboy97
Appreciate the help guys. I plan on recording the first startup so I'll share it with y'all.
Here's what I plan on doing, tell me if it sounds good: use a break in oil and prime the oil really well and spin the motor over with the plugs out for a bit. Start the engine up and let it idle on its own for a couple minutes to warm up. Then shut her down, check for leaks. Then for the next 750-1000 miles vary the rpms, no extended idling or steady cruising. No high rpms (>3000) and no WOT. Then after the 750-1000 miles, change the oil and filter with normal motor oil and drive normal.
Tanner
Old Oct 16, 2014 | 12:11 AM
85e150's Avatar
85e150
Without getting into a mile-by-mile explanation:
--make sure it's tight and not leaking or overheating when you first fire it up.
--run it easy, keep the revs low for your first outing. Pay attention to leakes, heat, oil pressure.
--once you have run it long enough to check for leaks, oil pressure, funny noises etc, give it a short burst of WOT.
--If all is ok, include some WOT in each run.
Wide open throttle produces the most cylinder pressure, and that's what forces the rings into the cylinder walls, and that's what wears the rings in properly and "seats" them, making for a good seal.
Good luck with it.
Old Oct 16, 2014 | 10:48 PM
fordboy97's Avatar
fordboy97
Good luck with it.
Thanks man. So its ok to get the rpms up pretty high during the wot?
Tanner
Old Oct 17, 2014 | 04:51 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What's redline in your truck?
5,800 like mine?
To add to 85e150six...,
Be sure to set your ignition timing correctly before hitting the road.
You don't want advanced detonation or retarded overheating to hurt your new engine.
Opening the throttle plates allows the cylinders to fill completely.
People break in engines on the dyno all the time.
WFO is different than taking it to the moon and keeping it there.
Old Oct 17, 2014 | 06:48 AM
  #28
fordboy97's Avatar
fordboy97
5,800 like mine?
I don't know what the red line is, I've never reved it that high.
And did you mean wot? Not sure what wfo means lol.
I'll make sure to check the timing with a light while cranking before the first start.
Tanner
Old Oct 17, 2014 | 08:12 AM
  #29
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wide F****** Open!
You need to check the timing at idle with the vacuum or Spark OUT disconnected.
Like explained on the emissions sticker.
Just set it static and start the engine.
You won't hurt rollers like you would a flat tappet cam.
Old Oct 17, 2014 | 12:21 PM
  #30
fordboy97's Avatar
fordboy97
Awesome. So the break in period for a roller engine is primarily to seat the rings?
Tanner
TopSgtLawrence
Engine Swaps
Feb 18, 2023 09:04 AM
madclone
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 4, 2009 01:37 PM
TopSgtLawrence
Engine Swaps
Mar 10, 2008 04:13 AM
Danny D
Dec 14, 2006 09:56 PM
Charly King
General Automotive Discussion
33
May 28, 2004 09:24 PM
