E4OD od light blinking
Old Oct 13, 2014 | 12:33 PM
Crewcabber's Avatar
Crewcabber
Ive been working my *** off we just bought out another company and got that all situated and i was at a car show this weekend.
Old Oct 13, 2014 | 12:57 PM
daddylee100's Avatar
daddylee100
Right on man, working is good. Get that money! Route 66 at the stadium?
Old Oct 13, 2014 | 01:01 PM
Crewcabber's Avatar
Crewcabber
Thunderfest in Covina awesome show
Old Oct 13, 2014 | 11:32 PM
Crewcabber's Avatar
Crewcabber
Alright finally scanned the beast.
Koeo
111
Continuous codes:
172 ego not switching
Small exhaust leak.
542 Fuel pump open Eca to ground.
If I switch to the front tank it pegs past full does not cycle on realy is good. Bad Fdm or sender or both?
628 excessive torque converter clutch slippage.
Just out of the blue? 169,000 miles.
638 trans Oil temp low signal low circuit ground.
I have no idea?? The truck wasnt warmed up.
657 trans over temp. Im assuming this is because of the tcc slippage.
Thanks in advance guys
Old Oct 14, 2014 | 06:46 AM
subford's Avatar
subford
I sure expected you would get a code 452 but without it the VSS input may be OK.
The 638 is normal for a cold transmission.
Not sure on an E4OD how you would get the 628 as the PCM would have to use the VSS input from the PSOM to know the clutch was slipping. There are no shaft sensors on the E4OD like on the 4R70W. Maybe you do have a bad VSS.
The 542 will happen with a bad fuel pump or tripped fuel shut off switch or if you ground pin #6 of the self-test plug to test the fuel system.
Old Oct 14, 2014 | 11:14 AM
Crewcabber's Avatar
Crewcabber
Thanks sub. I think this weekend ill crawl underneath her and disconnect some stuff and clean the connections. Ill pull the vss and clean it. Ill do a trans service and drain the torque converter and refill.
The tc has to be spun around and a bolt taken out to drain right?
How do you fill it back up? I want to check and make sure the filter is in place as well. Any other recomendations?
Old Oct 14, 2014 | 12:01 PM
rla2005's Avatar
rla2005
Great article: Changing ATF Fluid in a E4OD and 4R100 transmission - Ford Trucks
Old Oct 14, 2014 | 10:43 PM
Crewcabber's Avatar
Crewcabber
I crawled under her tonight and found out I have a pinion seal leak and a leak coming from the vss. Looks like some cleaning and sealing this weekend
Old Oct 14, 2014 | 10:51 PM
daddylee100
Well that explains the bouncing speedo but what about the Trans leaking fluid?
Old Oct 14, 2014 | 11:40 PM
Crewcabber's Avatar
Crewcabber
Im assuming that it got hot because it threw the over heat code. I havent had a chance to check the fluid to see what it looked or smelled like.
Old Oct 15, 2014 | 12:03 AM
daddylee100
Keep us posted, or at least me haha.
Old Oct 15, 2014 | 11:39 AM
daddylee100
Dave, let me know if you need any manuals on repairing, my brother is in vocational auto shop at San G and I have access to Pro Demand from Mitchell as well as Mitchell Vintage. That's where I got the diagram on the other HVAC post.
Old Oct 15, 2014 | 11:44 AM
  #28
Crewcabber's Avatar
Crewcabber
See if you can get the rebuild info for a 97 e4od. I already have the update manual i need the tear down and reassembly manual. I think im going to rebuild my trans myself.
Old Oct 15, 2014 | 12:12 PM
  #29
daddylee100
I got it. PM me your e-mail and ill send you a BUNCH of pages lol
Old Oct 15, 2014 | 12:51 PM
  #30
Crewcabber's Avatar
Crewcabber
There are more than 50 reasons why you should read the whole thread before you post sparky.
