Sagging springs?
Old Oct 15, 2014 | 11:04 AM
Tedster9's Avatar
Tedster9
Ok, will do. Just shot off an e-mail to them. Betcha they are probably better stuff than the johnny come lately firms.
Still a little unclear on some the hardware required to do this right.
See shackle kits in the catalogs - $170 for the front springs. $25 for the rear. These include the bushings and nuts and bolts to secure the springs??
Old Oct 16, 2014 | 07:58 PM
Tedster9's Avatar
Tedster9
Well I called a different company out in Cali that offers the springs. I mentioned that I wasn't sure exactly what parts were needed for my truck to complete the job and maybe they could help me put together a list of the parts and would buy those too. Probably $1500? Guessing.
They just said basically "figure out what you need and give us a call." Didn't push it, doesn't seem like that's the way to make a sale though. Hm.
Old Oct 16, 2014 | 08:22 PM
banjopicker66's Avatar
banjopicker66
Ted:
As promised.
B&T Sales Company INC
PO Box 1136
Skipjack, PA
610-584-5428
1-888-943-8287
Leaf Springs and Suspension Parts by Auto and Truck Springs Invoice dated march 2011.
Chevy replacement spring, 5/1 leaves, 2275 lbs capacity per spring (2-1/4X24X28) Uses 9/16 bolt, front and rear. Front and rear bushings supplied
Each $160 x 2 = $320
Shipping UPS Ground - $70
U-Bolt Kit Custom per sample - 1/2x3x7-3/4" Round, includes 2 U-bolts with deepnuts and washers.
$17 x 2 = $34
BT8-111SEB Leaf Spring Eye Bolt Kit, Grade 8 9/16"x4-1/2"
$11 x 2 = $22.
Total was $470.
I apologize for not getting the total correct in my previous post, but these are the actual numbers I paid in 2011.
Of course, I do not know if these prices will be good, so best of luck.
I unbolted the old springs (be sure to jack up the axle!) from the axle first, then took them off the truck. To re-install, I set the new spring on the axle, jacked the axle up enough to get one hanger bolt installed. Then I jacked it up the rest of the way, and buttoned it all up. One spring at a time, too.
John
Old Oct 16, 2014 | 08:38 PM
Tedster9's Avatar
Tedster9
Thank you!
I bet prices went up, that's not news. Looks good though and in line. So, those are part #s for F100 61-64??
Still planning on having a shop do it. Sometimes the best tool to have is a checkbook. I can do it ... Still just tell this is going to be one of those "shoulda done this a long time ago." Should improve cornering, ride, stopping, noise even? Anyway we'll check 'em out.
Hopefully somebody will respond a little better to "please take my money"; going to take the creeper out and spray down everything every couple days with ATF/Acetone mix for a couple weeks and figure out what all parts to order. Usually it takes a couple weeks for the springs to get made up. You figure they have the fronts too, no problem?
Old Oct 16, 2014 | 08:58 PM
banjopicker66
Ted, these went on my '66 F-100 with a Ford 9" rear axle, and I believe the rear springs were the same '61 - '66.
I can't speak to the fronts, though. Won't hurt to ask.
Old Oct 16, 2014 | 09:35 PM
Tedster9's Avatar
Tedster9
Ok sounds good. Will give them a call. Thanks for the help.
Old Oct 17, 2014 | 04:05 PM
LloydB's Avatar
LloydB
I've considered ordering a set from this company. My truck has terrible axle wrap.
1965 - 1972 F100 2 wheel drive rear leaf spring, 5(4/1) Leaves, 950 lbs capacity
Old Oct 20, 2014 | 03:37 PM
Tedster9's Avatar
Tedster9
Well I found a front spring shackle kit, that contains bushings and bolt hardware, from a couple vendors, $150 to $200 !...
but it's slim pickings for the rear springs as far as a complete kit is concerned, seems like I have to order front bushings for the rear springs from one company, and rear bushings from another, and the bolts themselves from yet another.
Sheesh, seems like somebody would offer a kit that has everything ya need and nothin' ya don't. Then there's the matter of U bolts. Seems like these should be replaced and not reused.
Old Oct 20, 2014 | 03:42 PM
Old_Crow's Avatar
Old_Crow
Google ESPO Springs and Things. I got a set of rear springs, shackles, bushings and ubolts for cheaper than LMC or people like that.
The springs came with their bushings already installed. The only bushings I had to buy extra were for the shackle end frame mounts.
Old Oct 21, 2014 | 07:45 PM
Tedster9's Avatar
Tedster9
Managed to find a complete shackle and bushing kit for the front springs, plus U bolts so that's taken care of.
Also, two shackle kits for the rear springs. Ended up buying all of this and a complete set of springs and shocks from Performanceonline.
But it seems that the shackle kits don't include the spring bushings for the front eye of the rear springs, and already ordered everything. Shoot. They told me the springs don't include bushings.
Figured the U bolt set they offered for the rear springs wouldn't be the right size, since there are helper springs on my truck. Need 2.5 by 9.5in.
Any other parts that should be replaced to do this right?
DBGrif91
May 20, 2012 07:52 PM
76gdmn
16
Oct 15, 2011 06:57 PM
misnomer
Apr 14, 2008 02:27 AM
oldfords4ever
All Things Towing
Jul 14, 2005 01:47 PM
DCS1
Oct 11, 2002 02:23 PM
