Rear Brakes Help
Old Oct 11, 2014 | 03:35 PM
GuitarJesus's Avatar
GuitarJesus
Rear Brakes Help
does anybody have a decently easy method of getting the backing plate springs attached to the hooks when reassembling the drum brakes?
That thing is a biznatch!
This is on a one ton.
Old Oct 11, 2014 | 03:52 PM
bashby's Avatar
bashby
There is a tool to do it, but ive always used an old straight screwdriver that i ground a notch in the tip.
with or without the tool you need to have the shoe in just the right spot and the spring facing just the right direction. I put the tip of my modified screwdri er on the tip of the holx down spring to compress it. Reach around the back of the backing plate with the other hand to manipulate the hook.
Tip: set the parking brake to get the lever out of your way. Dont forget to release it before trying to get the drum on.
Old Oct 11, 2014 | 06:39 PM
joey2fords's Avatar
joey2fords
x2 ... as soon as you notch an old screwdriver, your life suddenly becomes a lot better.
Old Oct 11, 2014 | 06:46 PM
GuitarJesus
A V notch? Square notch? What shape works best?
Old Oct 11, 2014 | 07:06 PM
bashby's Avatar
bashby
Whatever shape. Get about a 1/2" wide screwdriver and grind a notch in the tip about
1/8" wide. Push straight in on the spring tip. Without tbe notch the screwdriver tends to slide off.
Old Oct 12, 2014 | 08:27 AM
69HOSS96's Avatar
69HOSS96
Before I got the tool for this I would line up the pin and the top then while holding the pin in place with one hand I would use a set one lineman pliers to compress the spring and lock the catch in place
Old Oct 12, 2014 | 08:43 AM
turnkyle's Avatar
turnkyle
I usually use a combination of a pair of vise grip pliers clamped at the base of the spring perpendicular to spring and a screw driver in the hook of the spring. Usually not to bad but I have never done a 1 ton before....
Old Oct 12, 2014 | 11:30 AM
Nothing Special's Avatar
Nothing Special
That's how I did my F-250 as well.
Old Oct 29, 2019 | 09:19 PM
goodB0Y's Avatar
goodB0Y
Glad you got it fixed
*EDIT*
Oops... don't know how I ended up responding to a 5yr old thread lol
jwmayfield
18
Jul 22, 2013 03:32 PM
djf48
Feb 6, 2007 12:52 PM
spooey1959
Jan 12, 2007 07:01 AM
childsplay
Feb 26, 2005 09:57 AM
luke_trash
Jul 1, 2003 02:29 PM
