Safe Speed for Flat Windshield
Old Oct 13, 2014 | 08:11 PM
  #31
rswhitmore's Avatar
rswhitmore
Originally Posted by AXracer
A 49 F1 with Boss 5.0 mod motor owned/driven by Stan Fox's CART crew chief Don Basala went 95.008 MPH at 2012 ECTA Willmington, OH standing mile. Top speed on a public hiway doesn't impress me (only as a idiot). Show me a timing slip from Willmington or Bonneville.
So an f1 with a modified 5.0 is capable of 95mph in the quarter mile , and won't run another 35MPH if given a mile or two of straight road? I really don't care what you are impressed with AXracer, the discussion is about top speed.
Old Oct 13, 2014 | 08:34 PM
  #32
fladoodle's Avatar
fladoodle
I'd be interested to see all the modifications you've made to make sure the thing doesn't just fall apart at that speed. There's a lot of things not accounted for in your formula. As I'm reading all these estimates, all I'm reading is best-case scenarios in a perfect world. Is this 340 HP at the wheels or the crank? That makes a huge difference in what the truck will be able to do. I'm interested to see what is going to happen here. I'm not saying it can't be done, but I also don't want to see anyone getting hurt or killed over something so petty.
Old Oct 13, 2014 | 08:44 PM
  #33
49f3dls's Avatar
49f3dls
I've run at those speeds in a Porsche 911 S on the autobahn, a car built for that type driving on the track or roads built for high speed. I'm sure others on this forum also have done similar things on tracks or sometimes crazy enough to do it on common highways. These trucks were never built for that and no matter how much you modify it I can see no sane reason to try it especially on the deteriorated roads of Illinois. Go to the salt flats or somewhere similar and run it but do it in a safe place where there are crews to pull you from the wreckage if the truck is not capable of a safe run. You'll also have a great time with a lot of other guys doing the same type thing.
Old Oct 13, 2014 | 08:52 PM
  #34
49 Merc P/U's Avatar
49 Merc P/U
With regards to the windshield issue. If you go to bangshift.com there is a 1936 Chev pickup that runs 8.5 @ 159mph (with a 292 GMC 6 cylinder turbo) and they do not appear to have any problem. Sorry I could not post the link. If you are concerned I would think that a few tabs on the inside would avoid any issue.
Old Oct 13, 2014 | 09:24 PM
  #35
rswhitmore's Avatar
rswhitmore
[QUOTE=fladoodle;14739272]I'd be interested to see all the modifications you've made to make sure the thing doesn't just fall apart at that speed. There's a lot of things not accounted for in your formula. As I'm reading all these estimates, all I'm reading is best-case scenarios in a perfect world. Is this 340 HP at the wheels or the crank? That makes a huge difference in what the truck will be able to do. I'm interested to see what is going to happen here. I'm not saying it can't be done, but I also don't want to see anyone getting hurt or killed over something so petty.[/QUOT
Good points flatdoodle. I am going to back out of this for now until I get the truck back and finished. The engine has a list of modifications as long as your arm, and has made a dozen runs on a chassis dino in 4th gear from 2500rpm to just over 6,000rpm. I am not too worried about it coming apart.
Old Oct 14, 2014 | 02:09 PM
  #36
raytasch's Avatar
raytasch
Believe Nothing
If some of you high speed truck drivers are concern about the hood coming up you can always strap it down.
Ar. Hillbilly
Nov 15, 2023 10:38 PM
Melnickta
Jun 13, 2015 10:59 AM
NEWT92
Jan 6, 2008 10:15 PM
MeanGene1
2004 - 2008 F150
May 16, 2007 12:00 AM
BigF350
International Region
Nov 24, 2006 09:18 PM
