Defrost not working!
http://www.fordparts.com/Commerce/<O
</O
<O
</O
<O
</O
From the diagram it seems to be mounted on the end of the HVAC duct systems. Just above the driver’s floor heat nozzle.
<O
</O
FYI:<O
</O
<O
</O
The only module I see on the Duct System is for the fan motor speed. All the motors (actuators) are powered by the HVAC module (It could be behind the glove box?? <O
</O
<O
</O
The Defrost/Panel/Floor Actuator also has a feed back circuit so the climate control system knows what is going on.
Interesting! I would think if you operate the door in manual with the blower on low you would hear the motor, if you do, from the diagram I would maybe suspect the linkage.
</O
<O
</O
<O
</O
<O
</O
FYI:<O
</O
<O
</O
</O
<O
</O
Anyway, for those of you who read this, run out now and check your dash for any objects that could fall down inside the ductwork and jam up your mode doors because it's a time consuming and costly fix!
