Defrost not working!
Old Oct 10, 2014 | 10:32 AM
thejean's Avatar
thejean
Defrost not working. Looking for the vacuum pump so I can troubleshoot it. Can some tell me where to find it in the engine bay and advice on trouble shooting it other than listening to whether it's on or not when engaging 4x4? Thanks, JC
Old Oct 10, 2014 | 01:07 PM
thejean's Avatar
thejean
Starting to wonder if there is a vacuum pump even. I traced the hub lines all the way up to a little doohickey on the side of the coolant reservoir (I think). I'm at a loss…
Old Oct 10, 2014 | 01:24 PM
senix's Avatar
senix
There is a pump. If you look at the tech folder and download the bible that should help with parts id.
It is somewhere around the Primary water pump if I recall.
Old Oct 10, 2014 | 02:14 PM
thejean's Avatar
thejean
Thanks Senix. I had a look in the tech folder and don't see anything that looks like a service manual. I'll keep poking around...
Old Oct 10, 2014 | 02:17 PM
senix's Avatar
senix
it is not a service manual..rather the bible. that gets published.
Old Oct 10, 2014 | 02:35 PM
thejean's Avatar
thejean
Ah, I see what you are referring to now in the DTS. However, that link doesn't work for me and I cannot register for their site because I am not a Ford technician.
Old Oct 10, 2014 | 03:06 PM
senix's Avatar
senix
Vacuum Pump
The vacuum pump is located on the
upper portion of the front cover and is
driven by the high pressure fuel pump.
Vacuum is used for the EGR cooler
bypass system and the wastegate
control system.
Old Oct 10, 2014 | 03:08 PM
senix's Avatar
senix
If you follow the vacuum line from the degas bottle to the front of the motor by the HPFP then you should see it with a flashlight.
Old Oct 10, 2014 | 03:25 PM
EO2SeaBee's Avatar
EO2SeaBee
https://www.ford-trucks.com/forums/1...il-leak-4.html
There may be some helpful information in there about your pump. There are a few pics.
Old Oct 10, 2014 | 05:05 PM
jfritz_drfritz's Avatar
jfritz_drfritz
I thought any necessary vacuum was generated by the power steering pump
Old Oct 11, 2014 | 12:15 AM
Jus2shy's Avatar
Jus2shy
You're thinking more about "Hydro-boost" which is a totally different system and method, but it performs all the same work as what a vacuum pump on the powerstroke does.
Old Oct 13, 2014 | 03:28 PM
thejean's Avatar
thejean
I went to the dealer and looked at the fiche. Looks like the vacuum pump doesn't run the hvac flapper like previous trucks. There is an electric motor now. I picked it up for $160 but I think I need to rip the dash apart to replace it.
Old Oct 20, 2014 | 02:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, was going to say, vacuum doesn't operate the HVAC blend doors.
Old Oct 24, 2014 | 10:21 PM
thejean's Avatar
thejean
I spoke to my brother-in-law and he thinks that the problem might be due to the modulator behind the glove box. Is there even such a thing on the newer fords?
Old Oct 25, 2014 | 06:47 AM
senix's Avatar
senix
Blend door motors....
