aod transmission will not shift
Old Apr 18, 2002 | 02:19 PM
mauricecraig's Avatar
mauricecraig
The transmission in my 1986 F150 Custom Van seemed to be slipping in overdrive so I started by changing the fluid. It cured the slipping but now it won't change from second to third . Is it possible for the box to be air locked ? Is there a blead nut ? The Govener on the rear shaft dirty or faulty ? The bands need torque set or something more major ? Any help would be appreciated . . . . .MO
Old Apr 18, 2002 | 07:54 PM
MARC's Avatar
MARC
With that model of overdrive transmission, there are not any "bands to adjust". It uses a shift pack mounted on top/side of the tranny. You can have it replaced for about 500.00 bucks or do it yourself easily for about 250-300 bucks. often thes trannys will have a slight leak tat seems to come from the oil pan, but is actually coming from a cracked housing on the shift pack. Be sure to have your fluid exchanged and then change your filter at the same time.
Marc
Old Apr 18, 2002 | 09:50 PM
John7894's Avatar
John7894
I could be wrong, but I thought that year had a TV cable/linkage, that did the shifting. It could be broken or out of adjustment.
John
Old Apr 18, 2002 | 11:06 PM
GREASYROD's Avatar
GREASYROD
hermannm2
2009 - 2014 F150
Jul 16, 2016 12:51 AM
baki-winnie
Aug 25, 2014 11:44 AM
frankiethethumper
Jul 12, 2014 07:17 PM
78F460
Oct 20, 2006 08:08 AM
satcomjimmy
25
May 10, 2006 02:15 PM
