Just ordered my third 6.7
Old Dec 1, 2014 | 11:58 AM
  #31
jwp98's Avatar
jwp98
Originally Posted by Troy Buenger
You also forgot the DEF tank that hang's below the frame well behind the passenger front tire for everyone to see. Looks hideous...
Agree that is awful, even with the benefit of a larger fuel tank.
I'd be tolerant of most any cosmetic compromise if Ford could convince me it was a step forward in function. New cab needs to be more than pretty, and needs to work, 1st gen, without 600 bugs.
Old Dec 2, 2014 | 12:25 AM
  #32
Tofan's Avatar
Tofan
I'd like to see a bigger cab...... Toyota's Tundra's cabs are bigger then my Super Dutys....F150s cabs are bigger then my cab....Mega Cab is bigger then my cab. I guess if I would say that I would like to see is just a BIGGER cab. I would say based on seeing all of the manufacturers, we have the smallest "full size cab" out of all of them. I mean why in the hell is the F150 cab bigger then the F250 or F350?????
Old Dec 2, 2014 | 10:34 AM
  #33
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by Dim Sum
I really like the idea of an aluminum truck. No more body rust issues to chase after. We will see what the 2016 brings to this truck. They do have some work to do in order to quit being slammed for having an "old" cab design.
Aluminum corrodes big time in a salt environment........
The Navy aircraft require a bunch of corrosion control maintenance. Salt air....
Even the P-3's that fly over the ocean but don't live on the carriers require special care.
Aluminum is not a cure-all.
Old Dec 2, 2014 | 10:49 AM
  #34
Big-Foot's Avatar
Big-Foot
X2 on everything Roy said....
Frankly I don't see this so much as a means to control corrosion as much as I see the aluminum body and other components as a means to reduce weight and increase fuel economy..
Also on corrosion remediation on aluminum sheet metal - it is much more difficult to get under control than is steel. Anodizing will help, but scratches in the anodizing will start to corrode almost immediately.
Old Dec 3, 2014 | 11:24 AM
  #35
jwp98's Avatar
jwp98
Agree. If Toyota or Nissan had 1/2 ton diesels available now it would be a tougher choice.
Old Dec 3, 2014 | 03:20 PM
  #36
Kauhana's Avatar
Kauhana
Is that what that is? I was thinking how terrible it looks...
Snowman 8
Aug 2, 2021 05:50 PM
BrianP77
Feb 7, 2018 02:53 PM
MurrayPro92
Jun 7, 2016 10:08 AM
zimm
6.7L Power Stroke Diesel
61
Jan 20, 2016 06:55 AM
Badford
May 16, 2002 11:14 AM
