Bronco II Ford Bronco II
Tune-up...fail.
Old Oct 5, 2014 | 12:06 PM
Scout54's Avatar
Scout54
Tune-up...fail.
Bought my boy a 89 bronco 2 with the 2.9 efi decided to do the tune-up thing plugs wires cap and rotor just basic stuff got it all back together with the correct wires to the correct places, at least I think I did I have went over the wiring diagrams and they seem to match. The engine turns over but it will not start. I'm at a loss need y'all's help.
Old Oct 5, 2014 | 12:36 PM
Old93junk's Avatar
Old93junk
Did you get the coil wire fully connected on both ends?
Old Oct 5, 2014 | 12:45 PM
Tedster9's Avatar
Tedster9
Check to see if rotor is sitting on workbench. It's been done before lol
Old Oct 5, 2014 | 01:07 PM
Scout54's Avatar
Scout54
Yes wires connected,actually took it apart twice to make sure rotor was sitting properly, it was and had moved into new position from trying to start it. I had the battery unhooked and some of the wiring harness on the pass side, by doing that does something need to be reset....I am thinking fuel system or would a fuse have blown by doing what I done?
Old Oct 5, 2014 | 02:06 PM
87 XLT's Avatar
87 XLT
Everything except the lights and horn is powered from the ignition switch. Are the headlights and horn working?
If you turn the key one click does the check engine light and other idiot lights and gauges come on??
If not you might have blown a fuse or fuse link.
Old Oct 5, 2014 | 10:06 PM
Scout54's Avatar
Scout54
Headlights horn are working and the other lights come on when key is turned to first click.
Old Oct 6, 2014 | 01:16 AM
87 XLT's Avatar
87 XLT
If your 89 is the same as my 87 the fuel pump wiring & relay is on the passenger side. When you turn the key 1 click the check engine light should come on & the fuel pump -which is in the tank- should run for 2 seconds. Does it?
Does your wiring diagram show a fuse or fuse link powering the pump relay?
On my 87 the positive battery cable is wired to the starter relay & the fuel pump relay is about a foot further back. The relay should click each time the key is turned 1 click.
Old Oct 9, 2014 | 09:40 PM
Scout54's Avatar
Scout54
First off thanks for all the help, thought I would let y'all know what the problem is...well I done everything correct by putting it all together by the diagrams and rotor and all but what I did not know was a previous owner put a new distributor in and it was put in wrong so now my firing order at the cap is my number one fires about where the number six is and so on. So thanks for all the help guys we are gonna leave it the way it is cause it runs great, of course I will be going to the electrical forums to find out why the brake lights are intermittent thanks again.
TheSterling
Jun 15, 2020 05:40 PM
mookie2066
Nov 9, 2015 07:13 PM
letsgomuddin85
Mar 22, 2009 12:04 AM
matejcekautoworks
1983 - 2012 Ranger & B-Series
Jan 11, 2009 03:58 PM
Catfish369
Electrical Systems/Wiring
Sep 12, 2004 10:28 AM
