Sponsored by: Real Truck
Transmission? Engine? Both?
Old Oct 5, 2014 | 09:27 AM
PO1's Avatar
PO1
Hello everyone and thanks for the help. I have a 2001 f250 7.3L. I bought it with 192,000 miles and have driven it to 206,000 in the last 6 months. When I put it in gear, the truck will "bog" down and sometimes die. I will have to refill the transmission fluid every 2 weeks but I can't find where it's leaking. Thoughts?
Old Oct 5, 2014 | 04:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My thoughts are that you need to clean it off and find where it is leaking from. Low fluid will cause stalls.
Old Oct 5, 2014 | 05:26 PM
hodge5's Avatar
hodge5
You can't find where it's leaking, or you can't see that it's leaking? Is it leaking trans fluid, or is it just disappearing?
Old Oct 5, 2014 | 07:00 PM
PO1's Avatar
PO1
I can't see that it's leaking anywhere. There is no transmission fluid under the truck, and there is never a puddle under the truck when it sits for a while. But I have to add fluid about every week and a half or so.
Old Oct 5, 2014 | 10:38 PM
phillips91's Avatar
phillips91
Like Mark said, I would completely clean the underside degrease it as much as you can. When transmissions lose fluid there is almost always a fluid trail(cracked case, bad gasket, bad seal, etc).
VaWahoo
Jun 14, 2016 11:46 PM
Merlin8188
Dec 16, 2011 09:11 PM
Becca_78
1983 - 2012 Ranger & B-Series
Sep 23, 2009 06:53 PM
Skandocious
Feb 17, 2007 02:37 PM
MitchPeters
15
Dec 13, 2003 09:05 PM
