Leaking fluid... From where!?
Old Feb 16, 2007 | 12:46 PM
Skandocious's Avatar
Skandocious
I have had my truck for 6 months and since I've had it, it has had a very slow leak. I find a drop hanging off of my bell housing everytime I park. There are never any puddles under my truck, maybe a drop every once in a while, indicating that the leak occurs when the engine is running. The fluid is brown and smells burnt.
My tranmission fluid is new, just changed it about a month ago (Redline Synthetic ATF). I checked the tranny fluid anyway, and its very red and does not smell burnt.
What other fluid might have a burnt smell to it AND be dripping from the bell housing? Also I noticed that now it is dripping from my front axel too, which probably rules out transmission, unless I have a busted cooler line but then I would probably be leaking quite a bit more.
-Chris
Old Feb 17, 2007 | 10:26 AM
nighthawk285's Avatar
nighthawk285
crawl under there, clean everything you can, and then check pretty frequently to find it again....then its path of travel would be evident. since you say brown I'm thinking thats oil, why it smells burnt I dunno, but I'll bet your pan gasket is out in the front and the back, creating that leak on your axle too.
Old Feb 17, 2007 | 02:09 PM
Skandocious
Yeah I've been watching it for a while (as has my brother) and we can't figure it out. I have cleaned everything up down there but I just can't see where its coming from. I don't think its motor oil because of the smell. And it is a real soft kinda light brown (almost like it COULD have been red at one point, but it sure doesn't look like it).
-Chris
Old Feb 17, 2007 | 02:20 PM
luke245's Avatar
luke245
I'm not betting on transmission fluid but it could be brake fluid, power steering, or engine oil.
Old Feb 17, 2007 | 02:26 PM
dansmurf's Avatar
dansmurf
Oil dripping from rear of valve covers, heads, oil pan orrear main seal could drip down the bellhousing. Use a small mirror and check around the back of the heads.
Old Feb 17, 2007 | 02:37 PM
wrenchturner's Avatar
wrenchturner
if possible clean the motor. and start looking then. most likely it is the pan gasket though. mine spit out on my old sable and would smoke when i cornered.
97expedition08
Sep 11, 2012 05:05 AM
knash0727
Aug 3, 2010 11:35 AM
thunderz11
Apr 28, 2008 07:01 PM
I LUV WI
1997 - 2003 F150
Dec 31, 2004 06:23 PM
