Idle issues
Old Oct 5, 2014 | 06:20 PM
bashby's Avatar
bashby
Originally Posted by bduemig
mine was stalling after taking it out of storage. I would be running and when i came to a stop, the rpm dropped and it stalled. I removed the fuel filter, filled it with Diesel Clean, ran it for a bout 15 seconds and left it sit over night. problem solved.
ATF works also and is cheaper.
Old Oct 5, 2014 | 07:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
the key here though that suggests the issue is external linkage is because the trans control unit is sensing that TPS/FIPL is going out of range.(he wont get code 23 when he scans because when he goes to scan,he holds WOT and all is right with the world during the scan) so the flashing od light is suggesting that the sensor is physically being twisted beyond it's range which tells the teca,uh oh and trips the code (flashing od light) until the idle returns to normal/sensor turns up where it belongs.
if the od light wasn't flashing,then one would know to simply clean the ip (ATF works super when this stalling issue happens on deceleration in my experience too.)
it still should be just about as easy a fix.
lets go pats!
(going to make popcorn.see ya!)
Old Oct 5, 2014 | 07:28 PM
Larryd8563's Avatar
Larryd8563
What is the ip you are refering to?
Old Oct 5, 2014 | 07:41 PM
bashby's Avatar
bashby
IP is injection pump.
B1GKAHUNA
Apr 9, 2014 09:18 AM
Lastwagen
6.7L Power Stroke Diesel
Jul 16, 2012 08:02 AM
Crazy2
20
Dec 23, 2011 11:08 PM
FARM69
Jul 5, 2006 08:59 PM
