starter going?
Old Oct 1, 2014 | 03:26 PM
Jblack's Avatar
Jblack
starter going?
OK problem just sarted. Truck has been starting fine. Other day I hit the key and the starter spins but doesn't turn over the engine. tried a few times. Pulled the starter (which is oil soaked from bad gaskets above) and took it to NAPA to have tested. works ok there. teeth are a little buggered up but not bad. Reinstall and I bar over the engine thinking maybe a bad spot on flywheel. Starts right up! works fine for a couple days, does the same thing. bar it over and still nothing. So I'm thinking the bendix isnt indexing everytime? thoughts?
Old Oct 1, 2014 | 05:37 PM
resonateur's Avatar
resonateur
If you're sure the starter is spinning (at the necessary speed) and not turning over the engine, it has to be the starter drive (bendix) or a bad spot in the ring gear. I would first inspect the ring gear all the way around and rule it out before replacing the starter drive.
Mike819
16
May 26, 2021 04:23 PM
Funke1
Nov 26, 2015 08:54 AM
truckpastor
23
Jan 12, 2014 06:30 PM
BigBlockF350
Feb 21, 2013 08:53 PM
gingerbreadmaniac
Aug 26, 2005 05:14 PM
