Jblack |
10-01-2014 03:26 PM |
starter going?
OK problem just sarted. Truck has been starting fine. Other day I hit the key and the starter spins but doesn't turn over the engine. tried a few times. Pulled the starter (which is oil soaked from bad gaskets above) and took it to NAPA to have tested. works ok there. teeth are a little buggered up but not bad. Reinstall and I bar over the engine thinking maybe a bad spot on flywheel. Starts right up! works fine for a couple days, does the same thing. bar it over and still nothing. So I'm thinking the bendix isnt indexing everytime? thoughts?
