Sponsored by: Real Truck
can't get an alignment
Old Oct 1, 2014 | 01:37 PM
rs0630's Avatar
rs0630
I'm new this site, just put four new tires on my truck and the shop said they couldn't align the front end because they were afraid alignment sleeve with strip. has anyone ever heard of such a thing? 04 f250 super duty 88,000 miles
Old Oct 1, 2014 | 01:49 PM
r2millers's Avatar
r2millers
Huh?
Once it's loosened, it should turn without too much force. These sleeves and threads are mfg'd for regular adjustment.
If done on the proper equipment, I can't imagine any issue.
Either they saw previous damage or they used this as an excuse if not comfortable with aligning these trucks. Pretty simple procedure as used for toe alignment.
Old Oct 1, 2014 | 03:53 PM
speakerfritz's Avatar
speakerfritz
if you roll the front tires on to large cookie sheet pans, this will allow the wheels to move while adjusting the sleve very easy.
but obviously...if your shop does not know that...you need to find another shop.
Old Oct 1, 2014 | 05:16 PM
rs0630's Avatar
rs0630
Fixed, I got the alignment "teck" to at least put the truck on the rack and check the alignment (that I had already payed for). It turns out it didn't even need any adjustment. Some young know it all probably fresh out of school said "if you back up with the plow on the truck in 4wd it could pull the adjustment sleeve off the tire rod ends"... I don't think so
Old Oct 1, 2014 | 05:45 PM
jesse5's Avatar
jesse5
"Some young know it all probably fresh out of school said "if you back up with the plow on the truck in 4wd it could pull the adjustment sleeve off the tire rod ends"... I don't think so"
LOL that's funny.
If you ever do have to have the sleeve removed have anti seize placed on the threads for easy adjustment the next time.
Old Oct 1, 2014 | 08:37 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Why the need for an alignment? I don't get why people who drive vehicles with solid front axles think or get talked into a front end alignment? Its leaf springs nothing goes anywhere, I've added lifts to my 04 my dads 00 and a couple buddies 99-04 super duties and besides adjusting the drag link to re center the steering not one has ever needed an alignment. Even the owner of the local shop in town laughes when people ask about this on solid axle trucks, unnecessary unless something is wrong
galaxy S4 using IB AutoGroup
Old Oct 2, 2014 | 05:52 AM
rs0630's Avatar
rs0630
$1000 in tires, I think having the front alignment checked is well worth it.
Old Oct 2, 2014 | 09:18 AM
SuperDutyScaler
again was there a problem before? If not why do it?
Old Oct 2, 2014 | 09:41 AM
rs0630's Avatar
rs0630
Preventative maintenance; why change your oil it wasn't giving you a problem before
super 6.8
Nov 23, 2017 05:30 PM
03F2507.3
Mar 31, 2009 08:05 PM
craziejoker
Sep 20, 2008 06:03 PM
DCRB
Aerostar
15
Dec 19, 2007 12:19 AM
rdahl
Sep 4, 2003 04:26 PM
