79 Super Cab Hangers
Old Sep 30, 2014 | 10:37 PM
aczar's Avatar
aczar
I have searched all over and can not find a viable answer. I am in need of a OEM style front leaf spring hanger for a 79 F-150 S/C and have been out of luck. Does anyone know of a place to get one????
Old Oct 1, 2014 | 06:48 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
JY....F250 should be the same? Or maybe here?
Spring & Shackle Hangers - RuffStuff Specialties
Old Oct 1, 2014 | 08:26 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Are you talking about the front hangar that bolts to the frame horn or the rear shackle that is made up of two links.
Bracket, spring, front, 2 req.
D7TZ-5340-A
No dealer or obsolete parts supplier shows any in stock
Bar, front spring shackle, 4 req.
D7TZ-5468-A
Freese Motors, Monticello, IA shows 1 in stock (319) 465-3541
Last dealer cost $5.02 list $8.37
You might also check with Bronco Graveyard, sometimes they have used parts available.
Old Oct 1, 2014 | 08:53 AM
77&79F250's Avatar
77&79F250
Remember the F150 Super Cab has front leafs and not the normal F150 coil spring and radius arm set up.
Old Oct 1, 2014 | 11:06 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, the catalog illustration lumps the F150 Supercab in with the F250 4WD.
Section 53 Page 21 in the illustrations.
Old Oct 1, 2014 | 05:18 PM
lafermedavid's Avatar
lafermedavid
front hangers
Old Oct 1, 2014 | 06:32 PM
aczar's Avatar
aczar
[QUOTE=mikeo0o0o0;14706978]Are you talking about the front hangar that bolts to the frame horn or the rear shackle that is made up of two links.
Yes I am speaking of the front hanger that bolts to the frame.
Old Oct 1, 2014 | 06:56 PM
brian1080's Avatar
brian1080
They are the exact same as 4x4 F250 reg cab and Scab. Nothing unique about being an F150 Scab in that regard. You should be able to find them easy.
Hanger on right is 78 F250, left is 78 F150 Scab
wigpro
Modular V10 (6.8l)
Apr 27, 2014 08:32 PM
flcracker9
WTB - Parts & other
Jan 15, 2011 03:03 PM
MMarty
Jun 16, 2006 06:52 PM
bigf150
Aug 7, 2001 11:30 PM
