What is this sensor??
Old Sep 30, 2014 | 06:30 PM
Nolo263's Avatar
Nolo263
Found this with plug unhooked what is it and should it be hooked up?
Black sensor above green conection.
Old Sep 30, 2014 | 06:46 PM
holeshotwalt's Avatar
holeshotwalt
What vehicle/engine is this? Sorta looks like a 7.3 but being sideways and so close I'm not sure...
Old Sep 30, 2014 | 06:49 PM
Nolo263's Avatar
Nolo263
Sorry 2002 excursion 7.3
Old Sep 30, 2014 | 07:07 PM
Nolo263's Avatar
Nolo263
I gound a picture on another site that sais its the wastgate sensor. But i have a aftermarket turbo "turbonetics" should this be hooked up?
Old Oct 1, 2014 | 10:15 AM
holeshotwalt
If you still have a vacuum controlled wastegate, I would think it should be hooked up. Are you not getting any codes thrown?
Old Oct 1, 2014 | 03:50 PM
Nolo263's Avatar
Nolo263
I have not checked with a scanner but the cel light is not on. I was also told by dp tuner to connect it. The ex was like that when i got it. Problem is it has so much stuff on it that its hard to know what is what. I have been trying to get ahold of the past owner to ask what it has.
Old Oct 1, 2014 | 03:52 PM
Nolo263's Avatar
Nolo263
Here is a link to another forum. This is my ex. I have sent emails to everyone trying to find info but no luck.
One bad *** excursion build for blackops - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old Oct 2, 2014 | 05:08 PM
holeshotwalt
Nice ride!!
Even tho you're not getting codes, I'd plug the sensor in and see what happens. If they had not wanted it there when they did the build, you would think they'd have eliminated it.
Old Oct 2, 2014 | 07:08 PM
hav24wheel's Avatar
hav24wheel
Not only is the wires not plugged in, it's missing a vac line.
Old Oct 3, 2014 | 05:43 AM
carbon coupe's Avatar
carbon coupe
If you dont have this (red circle), you probably dont need the actuator. If you do have it but there is another vacuum line plugged in, you should be fine.
Projectlittleredf250
Ford Truck Parts for Sale
Mar 9, 2017 09:20 PM
Jsean Jackson
Jan 20, 2017 10:31 PM
renchr56
May 15, 2015 08:37 AM
kawirider00
Feb 2, 2012 01:31 PM
cdiddy
17
Dec 31, 2006 02:24 PM
