Sensor Readings???
Old Sep 30, 2014 | 07:50 AM
polosabre's Avatar
polosabre
Sensor Readings???
My IAT2 is reading -39, MAP 112, and MAF 1 at idle. Will this cause my turbo to produce high boost before it should? Found out why my IAT2, and MAF readings are off. They are unplugged. I plugged the MAF sensor in but couldn't get to the IAT2 sensor. I will have to take some parts off to get to it. I did see a difference in boost coming up hill. The boost only reached 14 where it was reaching 26 on flat surface normal driving. Still not sure about the MAP sensor reading. The brass plug that goes into the intake that the hose connects to will pull out of intake manifold. Any suggestions on a fix for that? Thanks for all the help I have received?
menmy02x
Sep 26, 2016 08:42 AM
Militant83
Feb 10, 2015 05:18 PM
Greg W.
Dec 29, 2012 01:27 PM
bobrc
Aug 24, 2008 12:56 PM
teamroper98
Jun 1, 2006 09:07 PM
