Help!
Old Sep 29, 2014 | 06:52 PM
Griffin9's Avatar
Griffin9
Help!
Hi, I have a 95 F250 7.3 turbo diesel and I changed the exhaust to 4 inch MBRP turbo back and ever since I did that the truck hasn't had any power at all and threw a turbo charger code and the truck will not go over 60MPH. I'm guessing its a fuel problem but it doesn't explain why after I did the exhaust it happened, please help.
Old Sep 29, 2014 | 06:54 PM
DIYMechanic's Avatar
DIYMechanic
Does the truck run and idle smoothly? It sounds to me like something happened to the EBPV system and it is keeping the valve closed all the time. Try unplugging the 2 wire connector right under the turbo intake. If that fixes it, just leave it unplugged and you'll be good to go for the next 200k, lol.
Old Sep 29, 2014 | 07:04 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
WHS
If all you did was replace the exhaust, then the EBPV is likely the issue. Take the downpipe off to see if it is bound closed.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Sep 29, 2014 | 07:06 PM
Griffin9's Avatar
Griffin9
The truck runs good and the Idle can be a little off sometimes but its not a rough idle, I mean its a 95 lol
Old Sep 29, 2014 | 07:10 PM
Griffin9's Avatar
Griffin9
The fuel filter light is on also, when I drive it flickers this is why I thought its a fuel problem because it doesn't go over 60 mph it acts like its struggling to get fuel
Old Sep 29, 2014 | 07:25 PM
Griffin9's Avatar
Griffin9
I will try that and the fuel filter light Is on, that's why I was thinking there is a fuel problem I don't know what else to try lol
Old Sep 29, 2014 | 07:41 PM
427 fordman's Avatar
427 fordman
Have you drained the fuel bowl, and/or changed the fuel filter?
Old Sep 29, 2014 | 07:49 PM
Griffin9's Avatar
Griffin9
yes I have
Griffin9's Avatar
Griffin9
when I change the fuel filter and drain the fuel out, do I fill it back up?
Old Sep 29, 2014 | 08:02 PM
427 fordman
You can, it will start faster. You don't have to, it will fill itself while cranking.
Old Sep 29, 2014 | 09:20 PM
DIYMechanic
Check the fuel pressure then too. There is a fitting on the side of the fuel bowl that you can use a standard tire pressure gauge on to check the pressure. You're looking for about 65 PSI at idle. If you're way below that and the mechanical pump is failing that will definitely make it run poorly.
Does it act the same way on both tanks?
Old Sep 29, 2014 | 09:48 PM
oldbird1965's Avatar
oldbird1965
Does it do it on the other tank?
Old Sep 29, 2014 | 11:12 PM
ReBilld's Avatar
ReBilld
Check the small hose that goes from the pass side intake plenum up to the map sensor. You may have pulled it loose while working on the down pipe.
Old Sep 30, 2014 | 07:25 AM
madpogue's Avatar
madpogue
What was the CODE?
GR8Dane
6.7L Power Stroke Diesel
Dec 9, 2017 11:31 AM
ol.paynt
Nov 17, 2010 04:46 PM
dayooper
Feb 20, 2008 10:54 PM
D.S.
Apr 10, 2005 09:05 PM
Ben Alston
Feb 25, 2005 10:05 AM
