blinker issues
Old Sep 29, 2014 | 11:43 AM
my75ford's Avatar
my75ford
blinker issues
Any ideas why blinkers would work when truck is first started, then just quite? I want the truck to be road safe. I dont need any more tickets.
Old Sep 29, 2014 | 06:49 PM
HIO Silver's Avatar
HIO Silver
Sure. It's an electrical problem. More investigation and troubleshooting required for you to do....
When the signals quit, do the hazard lights and flashers still work?
Do all of the turn signal lamps work or just fail to flash (cycle)?
Review the circuit diagrams and find the likely culprit. Post back your findings.
Old Sep 29, 2014 | 07:41 PM
my75ford's Avatar
my75ford
Thanks hio. The hazard do still work. Not all lamps work (passenger rear dont work at all). I am not to good at reading circuit diagrams, but will look into it. Any ide where to find one?
Old Sep 29, 2014 | 07:46 PM
HIO Silver's Avatar
HIO Silver
The electrical section of the tech compilation sticky.
Old Sep 29, 2014 | 08:23 PM
HIO Silver's Avatar
HIO Silver
'Got your message...
https://www.ford-trucks.com/forums/1...l#post14213910
Old Sep 29, 2014 | 09:12 PM
iowa79superdent's Avatar
iowa79superdent
I am kinda having the same problem my dash turn light arrow is on when my lights are turned on I haven't looked into it yet so it may be a backwards wire and would this cause the park light to not work
Old Sep 29, 2014 | 09:27 PM
HIO Silver's Avatar
HIO Silver
C'mon boys.... you can do it. Barring hacked wiring there are really only TWO logical possibilities.
.. and wires don't mysteriously become "backwards"... Unless of course Obama is teaching basic electricity these days.
Old Sep 29, 2014 | 11:41 PM
TheStuffz's Avatar
TheStuffz
Cheap fix - new bulbs and di-electric grease!
Old Sep 30, 2014 | 03:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/77 F100/350:
Two 2 prong flashers, one for the turn signals, a H/D unit for the 4 way flashers.
Three different T/S switches: A/T, M/T, 1975/77's with Speed Control.
Old Sep 30, 2014 | 12:24 PM
ZarK-eh's Avatar
ZarK-eh
1973/77 F100/350:
You forgot the part numbers for Blinker Fluid!
jk, any update on this?
edit: I found these how to read schematics: http://www.wikihow.com/Read-Schematics
Hope this helps!
Also, some more how to's: http://www.popularmechanics.com/cars...enance/4314662 http://www.ask-the-electrician.com/h...ring-problems/
Tools you might need: a decent Multimeter and/or a testlight but mostly your brain is your best tool. If it helps, think of each wire as a pipe of electrons and flows about through them, through your load (lights) and then through the chassis (ground). (the wrinkle is that electrons flow from the negative to positive).
Also I really hate these light sockets And would be the first place I would look for leaking blinker fluid
Old Sep 30, 2014 | 05:35 PM
Roger Carter's Avatar
Roger Carter
edit: I found these how to read schematics: How to Read Schematics: 5 Steps (with Pictures) - wikiHow How to read and use your wiring diagram - YouTube Hope this helps!
Also, some more how to's: How to Diagnose Car Electrical Problems by Tracing Voltage Drops - Popular Mechanics How to Fix Car Wiring Problems
A pipe full of electrons? Way too complicated.
As an electrician, I always think of electricity as plastic tubes full of smoke. As long as the smoke stays in the tubes, all is good.
But we all know what happens when the smoke leaks out, don't we?
Seriously, Zark-eh offers some very good advice. Don't try to over complicate things. Take one wire at a time and prove it out. Make sure all connections are clean, tight and corrosion free.
slour
Nov 26, 2018 06:42 PM
Ryan Cunningham
Oct 26, 2016 06:24 PM
magnium1
Oct 20, 2011 03:26 PM
fokkersauras
Jan 10, 2006 01:04 PM
lilpig88
Electrical Systems/Wiring
Jan 24, 2003 07:49 AM
