Key-On, Accessory Power?? Help
Old Nov 15, 2008 | 05:26 PM
Bigfwt04's Avatar
Bigfwt04
I am needing to tap into a key-on, acc power source. Where can a lead to do it? I am in the middle of an install and realized I forgot to ask last night. Thx
Old Nov 15, 2008 | 05:43 PM
zx250's Avatar
zx250
Of the next Riffraff East
I don't know what to tell you right now other than it is much easier to find a key-on power than a constant power source. I usually use a meter or test light and start with the red wires and look until I find one.
Old Nov 15, 2008 | 05:51 PM
megawatt00's Avatar
megawatt00
I'm looking for the pic that I posted last week.
Old Nov 15, 2008 | 05:57 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look here for the wire you need. click here. This is off wireing the gauges in.
Under the dash there is a customer wire that you can use. It is labled just like that.
Old Nov 15, 2008 | 06:05 PM
megawatt00's Avatar
megawatt00
That's the pic I was just going to post Rick!!
Old Nov 15, 2008 | 06:09 PM
zx250's Avatar
zx250
Look at you guys using pictures, but I did tell him to start with red. Good job guys.
Old Nov 15, 2008 | 06:19 PM
mongo75's Avatar
mongo75
I use fuse #13 I think is- it's the one that is on the far right side, 3rd from the bottom. It's the one that powers the vacuum pump. I use it for my air compressor solenoid so the pump will only run when the ignition is on.
Old Nov 15, 2008 | 06:25 PM
miller_feed
Finally got the jump.
Old Nov 15, 2008 | 08:30 PM
Bigfwt04's Avatar
Bigfwt04
Thanks man! Works perfect. BTW, what is that plug meant for anyway?
Old Nov 15, 2008 | 08:49 PM
zx250's Avatar
zx250
Why that's the "if you need an extra wire look here" plug.
Old Nov 15, 2008 | 09:24 PM
megawatt00's Avatar
megawatt00
Yes you did!!
Is that the technical term?
