Pertronics Igniter Conversion
Old Oct 2, 2014 | 03:12 PM
Tedster9's Avatar
Tedster9
Seems to me one of the first Emissions controls was the air pump. "The solution to pollution is dilution"; it didn't decrease overall pollution but measured better at the tail pipe??
Old Oct 2, 2014 | 04:43 PM
JEFFFAFA's Avatar
JEFFFAFA
Catchy little phrase there Ted. I like it.
Air pumps were installed on various engines for various reasons. I'm sure CougarJohn and Ultraranger can add to my post and I welcome it. Some were for dilution as you mentioned. Some were to add oxygen back in to the exhaust to continue the burn. And some were to cool the exhaust valves because of the carb's lean mixture.
Old Oct 2, 2014 | 05:41 PM
Turbo Dog's Avatar
Turbo Dog
Originally Posted by 351Cleveland C4
What affect does timing have? I would think higher timing might help because it has more time to burn.
Advancing the timing gives the air/fuel mixture more time to burn, that raises the combustion temperature and that increases the amount of NOx (Nitric Oxides) created. The amount of NOx created is equal to the amount of time the combustion spends over 1450 degrees.
Retarding the timing decreases the amount of NOx created but creates more CO. Carbon Monoxide comes from incomplete combustion.
The ideal place to set the timing is so that the peak firing pressure is at about 16 to 18 degrees after top dead center. I can measure this on the large bore (18" bore) pipeline engines I deal with. They have a small port into the combustion chamber that I can hook up a pressure sensor to. I then record the pressure in relation to the crank angle. Here's one from a two stroke, a four stroke looks the same it just takes 720 degrees.
Old Oct 2, 2014 | 05:48 PM
Turbo Dog's Avatar
Turbo Dog
Yes, the air pumps just diluted the exhaust. The exhaust is only hot enough to continue burning for a very short time after leaving the cylinder. And that is only during high power output. When the engine is putting out nearly full power I've measured up to 1700 degrees at the exhaust port on automotive engines. During that time a bit more oxygen could help combust the HC coming out. Otherwise the oxygen is just diluting the exhaust.
Dilution is the answer to pollution...some times the engines I deal with just get mandated to have a taller exhaust stack. That helps dilute the pollution. When you drive by a very tall exhaust stack you can figure it's putting out al lot of pollution.
Old Oct 2, 2014 | 10:24 PM
orich's Avatar
orich
Originally Posted by 68fish
Back in the day here in Kalifornia you had to have a "smog kit" installed on older cars to pass smog. The "kit" consisted of a yellow sticker in the radiator support, a windshield sticker showing compliance, and last but not least. They would retard the ignition timing to reduce smog.
I never noticed the smog reduction, just the hotter running engine
Geez, I remember that in the early 60's when living in the North-East Los Angeles of Eagle rock & Highland-park area. Until 1974 the smog & rat race of people moving into the areas.. I moved to the desert to work. No smog & not many people
Orich
kawasakiklx1
46
Mar 18, 2018 10:15 AM
mountain dewd
75
Mar 21, 2016 12:12 AM
Randy2631
54
Aug 7, 2012 02:20 AM
vanwho
Electrical Systems/Wiring
May 17, 2009 08:12 PM
billybob_81067
Jun 9, 2008 11:27 AM
