72 Duraspark 2 Conversion
Old Dec 18, 2016 | 01:27 PM
kawasakiklx1's Avatar
kawasakiklx1
I've been researching this conversion and I've decided to do it. Here is what I ordered:
76 FE reman'd dizzy
76 FE ignition coil
GM HEI Module suggested in other posts
Heat sink for the HEI, with the heat sink silicone
I think the wiring diagrams I've found are pretty clear, but I'm left with one remaining question.
Do I need to run a resistor? I currently have the ballast type from my old setup. If I do need it, what do I hook it into? Should I make my own?
Thanks for all the help so far!
Old Dec 18, 2016 | 02:53 PM
nkf's Avatar
nkf
No resistor is needed. I did the same thing and have been very happy with it. I did add a TFI coil to mine. The change was enough that my wife noticed how much better it ran. I would run the big cap if you use the TFI coil. Less chance of carbin tracking.
Old Dec 18, 2016 | 02:59 PM
kawasakiklx1
What exactly is a TFI coil? I've heard two takes on it. It's either a module attached to the dizzy, or a coil. If I don't use TFI, do I have to keep the resistor?
Also, how do I lookup the "big cap"?
Old Dec 18, 2016 | 07:08 PM
nkf's Avatar
nkf
Resister wire is the old wire that ran to the factory coil. I would double check it to see if it is 12 volts or less. If less 12 volt run a new wire from the switch out.
TFI coil is used in the late 80’s to sometime early 2000's (I do not remember the exact years; I just know it was fuel injected and still has a dizzy in it) 460 with fuel injection and a dizzy in it. It is a true 45,000 volt coil. Most bone yards sell them for just a few bucks.
For the TFI coil, you will need to fab up a bracket for it. Mine will get a new bracket for it over the winter as it was just a quick peace of scrape metal that I used.
Old Dec 18, 2016 | 07:35 PM
kawasakiklx1
So a coil like this?
What else would I need to do to use this with a 76 dizzy and a GM HEI?
Old Dec 18, 2016 | 07:47 PM
ultraranger's Avatar
ultraranger
The coil is an E-core design. You would have to have the connector to plug into it.
MSD 8227 Mustang Ignition Coil Tfi 1986-1995
This is a factory E-core coil/connector pigtail/bracket I pulled from an '83 Bullnose F150 that was on an inline 300 engine.
Old Dec 18, 2016 | 08:03 PM
nkf's Avatar
nkf
I forgot the 300 had them. You can pickup all new part at most part stores. I have not seen a TFI coil go bad. So I rolled the dice and went with used for under $5.00. That also included the short pig tail and connector to the coil.
Old Dec 18, 2016 | 09:07 PM
kawasakiklx1
The plug is the only thing I'd have to come up with? No other mods needed?
Old Dec 18, 2016 | 09:11 PM
ultraranger
You may have to fabricate a mounting bracket to mount the coil to the FE engine but otherwise (besides the connector), that's it. --the coil could also be mounted to the inner fender apron.
Old Dec 18, 2016 | 09:26 PM
kawasakiklx1
Great, got it ordered. Does the mount I make need to be grounded?
Old Dec 18, 2016 | 11:18 PM
nkf's Avatar
nkf
I did ground mine. I have amateur radio equipment in mine so that is the normal for me. Are you going with the big cap on it or the small?
Old Dec 19, 2016 | 12:14 AM
kawasakiklx1
What do each cap go on? I need to look them up based on their application.
Is the stock 76 F250 cap big or small?
Old Dec 19, 2016 | 08:39 AM
nkf's Avatar
nkf
I had the adapter to take in from small cap to big cap. Wires I had from a 351M that did not get used. You might be able to get all for application?
Old Dec 19, 2016 | 08:51 AM
orich's Avatar
orich
Oem fe 76 cap is small, all V8's 77 &up use the lager cap with matching rotor that mounts on top of the tower housing. Both you can buy at your loco parts store. Buy the cap with brass contacts.
Also you'll need the later spark plug wires to fit the larger cap.
I think, I ordered the 77 460 wire set
Orich
Old Dec 19, 2016 | 11:03 AM
orich's Avatar
orich
If the E-core type coil is to be used, I'd then use the supper duty 8.5 spark plug wires.
Orich
