Looking for 1951 bed assembly drawing
Old Sep 26, 2014 | 02:37 PM
drptop70ss's Avatar
drptop70ss
Gents,
Will be getting the bed ready for installation soon on the 51 supercharged truck, does anyone have a diagram showing how the bed is bolted to the frame? Do all the mounting bolts go through the wood or are there bolts that hold the bed down underneath the wood pieces? My bed was loosely held down with a few bolts and no wood so nothing was as original to reference. I have a couple "Z" shaped brackets that I think go to the rear bed mounting but have not seen a diagram.
Also is there a diagram showing the dimensions of the wood pieces? I am going to cut my own for this build.
Old Sep 26, 2014 | 02:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
They all go thru the bed wood, except the two at the very rear underneath, on the rear crossmember, that bolt right to the frame. The Z goes at the front.
Old Sep 26, 2014 | 04:47 PM
drptop70ss's Avatar
drptop70ss
thanks, so the Z brackets go to the front? They are around 4" wide as I remember.
Old Sep 26, 2014 | 05:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There's only one Z-bracket, it goes as shown below. Are you talking about the crossmembers that go in front of and behind the axle? They are a top-hat shape.
Front of the truck is to the left in the pic. Ignore the bolt in the wood, that's for a bed box.
Old Sep 27, 2014 | 11:03 AM
drptop70ss's Avatar
drptop70ss
Thanks, the Z shaped brackets are only about 2" wide, for some reason I think they were used on the bed somewhere. All the crossmembers are in place but I have to straighten a couple of them.
Anyone have an assembly diagram?
Old Sep 28, 2014 | 10:35 PM
drptop70ss's Avatar
drptop70ss
These are the brackets I am trying to identify, I thought they went on the bed somewhere.
Old Sep 28, 2014 | 11:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Those "kind of" look like the brackets at the rear, attached to the frame. Mine are riveted on to the rear sill.
Old Sep 29, 2014 | 07:20 AM
drptop70ss's Avatar
drptop70ss
thanks, not those, mine are still riveted in place to the rear crossmember.
If they are not for the bed I sure would like to know where they go.
Old Sep 29, 2014 | 09:02 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I've never seen anything like it on the bed. Were they just laying in the truck when you got it? I suspect they are random parts from something else.
Old Sep 29, 2014 | 09:30 AM
51dueller's Avatar
51dueller
The 1951 F-1 I had years ago, had those brackets on the box. I think they went from the frame to the front panel.
Old Sep 29, 2014 | 12:23 PM
drptop70ss's Avatar
drptop70ss
Thanks, I was sure they were on the bed at one end but couldnt remember. I took a ton of pictures during the nose disassembly but nothing during the bed removal, too simple to need pics
Maybe Iilya or someone else who parts these trucks has seen them before. They were not on my other 1951 F1 that I can remember but they may have been removed.
Old Sep 29, 2014 | 01:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you have the full-width front Z-bar? I don't see how those of yours would support the front of the bed boards.
Edit, never mind, I forgot there's a lip on the front of the bed.
Old Sep 29, 2014 | 02:11 PM
drptop70ss's Avatar
drptop70ss
Yes, full width front Z shaped crossmember is there.
Narwhal
35
Jun 26, 2020 07:34 PM
Chiefdan
Mar 25, 2019 01:33 PM
04Z06Vette
13
May 4, 2017 10:11 AM
80stepper
21
Jul 19, 2012 12:13 PM
53 4 me
Oct 17, 2004 11:05 PM
