ok im getting ready to redo the org. bed on my 1980 ss and i have some questions.. any and all help is great.. thanks ahead of time. First how many bolts hold the bed to the frame? and is this what holds the wood to the floor? Second i have alot of cherry lumber (rough cut) to replace the wood or is this something left to the pros? will the cherry hold the job as good as the oak kits ive found at mar-k? but very pricey!! ok his should get me started it get drug into the shop tomorrow.. thanks again..
A 1980 stepside SS? Never heard of it, however, 8 bolts hold the bed to the frame. This is not what holds the wood to the bed. The wood is held to the bed independently by crossmembers bolted to the bedsides and the wood is attached to the crossmembers with bolts through the bed strips. You've checked Mar-K, they have a great diagram of a stepside bed and all it's components. I bought oak from a local lumber yard and cut and milled it from dimensions I got off the net somewhere.
ohh yeah the ss stands for step side.. no red in my blood!! Yeah im wanna turn into a show veh but its an as i go project and bed was in bad shape so i have to start there.. any idea where i can get the dimensions? yeah thanks to mar-k it helped but wasnt sure of all them bolts or where they were at...so 8 bolts bed and crossmembers all come out?
as a wood worker I can tell you the cherry will look real pretty, however i'ts not nearly as resistent to rot and decay as the oak. red oak is very resistent to rot/moisture, white oak is considered water proof, that's why it is used for wine casks, marine applications, etc.. . when I say red or white oak I'm not talking about color, I mean species. Also, cherry is photo-reactive, meaning it will darken over time from exposure to sunlight. If your looking more for show than usability, either type of wood will be nice (I"m partial to quarter-sawn white oak myself) just make sure you seal it well, especially the end grain to keep from splitting. Spar varnish is the finish I would recommend as it retains some flexibility after curing and will be less prone to crazing (hairline cracks) under the stress of the trucks vibrations.
hey thanks for all that info!!! im looking more towards an oak bed now just cause id like it to last.. but still going to plane the cherry and see what i got and maybe end up making a console.. but thanks for the info it was great help!!
whats it worth to you? i have two gates one better then the other but couldnt see 400 for a new one.. there are nice pieces tho.. whats your price? im in central pa so idk about shipping something that size either..
Good luck on your build. Just a thought here but soak every bolt you can with some form of penetrating oil. The bed sides and fenders are not reproduced. (As far as I know that is.) If a bolt is tough to undo cut it if you can. The "steps" are thin metal and a frozen bolt will tear the metal. I have 2 of these trucks. Both need beds rebuilt badly. As for wood and sealers I'm no help there. I myself haven't done much research yet. This summer I hope to get one done and on the road.
Seams like some great ideas when u start can u upload some pics would love to see how it turns. It save lots of money compare to the 400$ wood kits they have online
has any one done a body lift on a step side bed and if so what did you do different to match the cab lift? have not seen any wood kits for a 3" body lift for a stepside
