Sponsored by: Auxito
locking hubs
Old Sep 25, 2014 | 10:50 AM
j66b's Avatar
j66b
locking hubs
Does anyone manufacture manual locking hubs for a 1997 F150? Warn does not: something about the wheel design. Thanks, j66b
Old Sep 25, 2014 | 06:47 PM
steve(ill)'s Avatar
steve(ill)
The hub splines directly to the axle shaft. If would have to be a completely different design to have a manual lock as part of it.
Old Sep 25, 2014 | 08:43 PM
j66b's Avatar
j66b
locking hubs
Anyone know how to convert it so that it can have locking hubs? Thanks, JB
Old Sep 25, 2014 | 10:38 PM
steve(ill)'s Avatar
steve(ill)
THh new trucks use a hub/ bearing unit. That style will not work and can not be modified. I don't know if it would fit the spindle, but you would need an older style hub with the planet / engagement parts inside. The type that sticks out several inches pasts the rim. I don't know if this would even install on the new spindle.
kenn_chan's Avatar
kenn_chan
Yes, look up SAS that is probably the only way to put manual locking hubs on the 97 and newer 1/2 ton models.
Old Sep 26, 2014 | 12:24 AM
Torky2's Avatar
Torky2
IIRC, the truck design newer than the 1997-2003(and 2004 Heritage) went back to a hub-disconnect type of system. I have no idea if anything could be adapted to work.
Old Sep 26, 2014 | 07:14 AM
MBDiagMan's Avatar
MBDiagMan
Why do you want locking hubs? They were quite useful on old solid front axle 4X4's like my old '78 with a part time transfer case, because you are disconnecting a lot of rotating mass including the entire center section. With the 97 and newer as designed, however, the vacuum system disconnects the vast majority of the rotating mass when not in 4X4 mode. The gain from unlocking the hub would only disconnect the outer shaft which is relatively lightweight.
I6roughneck
13
Feb 12, 2019 12:11 AM
Jeremy Morgan
Offroad & 4x4
Jul 1, 2017 01:38 PM
jhinalabama
2009 - 2014 F150
Nov 16, 2012 12:37 AM
duga
1983 - 2012 Ranger & B-Series
Dec 6, 2007 08:18 AM
mary-kate
General Automotive Discussion
32
Dec 28, 2004 04:40 PM
