Key Switch Question
Old Sep 24, 2014 | 04:39 PM
JoeVol's Avatar
JoeVol
Key Switch Question
90 F250
I understand that to pull subject you merely need to insert a small punch in to the hole on the bottom side of the steering shroud, slanted towards the switch. I have found the hole but can not feel what it is that I'm supposed to press to release the switch. My purpose in needing to remove is that the key is stuck in the switch. The rod is not disconnected as the switch does turn and I removed the lower shroud for a visual. That said, can anyone advise as to what may be keeping the switch from being removed?
Old Sep 24, 2014 | 05:48 PM
Old Trusty's Avatar
Old Trusty
I had to fight mine I pulled it out with a pAir of needle nose with the lower shrowed off also.
Big pita
Old Sep 24, 2014 | 06:47 PM
JoeVol's Avatar
JoeVol
Old Trusty: Did you put the needle noses on the key itself? As for the hole in the bottom of the shroud....Am I supposed to be pushing, turning, or flipping something?
Old Sep 24, 2014 | 06:53 PM
Old Trusty's Avatar
Old Trusty
Key should be in the run position, push-up on the release pin in the bottom and pull the cylinder out. Yes I put the pliers in the keys lot but my chrome key guard was broken off. I had a lot more problems than the YouTube videos show I had to wiggle it around to get it to come out. I also had to tap the new one into place cuz it got bound in at an angle.
Old Sep 25, 2014 | 08:41 PM
Old Trusty's Avatar
Old Trusty
Did you get it?
romoshka
23
Apr 14, 2022 04:07 AM
oliver28472
Apr 24, 2013 05:18 PM
7.3 Rocket
Oct 25, 2010 08:23 PM
66F100Again
Dec 9, 2006 05:41 PM
TRIPLETS
Jun 19, 2006 10:14 PM
