Changing key switch
Old Oct 25, 2010 | 07:52 PM
7.3 Rocket's Avatar
7.3 Rocket
Changing key switch
Anyone know what's involved in changing the key switch on one of these trucks? Mine has been acting strange lately. It gets kinda stuck to where you have to turn the key forward a bit and then twist it back hard in order to get it to go to the off position. Plus the key can come right out of the switch no matter what position it is in.
Anyone know how to change one of these things? Trying to decide if it's worth it or not. Also do you think a new key switch would solve the issue or is it a larger problem?
Old Oct 25, 2010 | 07:56 PM
rbaker6336's Avatar
rbaker6336
The key has to be in the run position, then you reach up from the bottom side of the column with a very skinny screwdriver, awl, etc (something long and skinny... a small diameter drill bit would work) and push up on a pin that allows the tumbler assembly to slide out. The pin is accessed through the only hole in the plastic without a screw in it.
or just look here https://www.ford-trucks.com/forums/1...ust-broke.html
__________________
Old Oct 25, 2010 | 08:23 PM
7.3 Rocket's Avatar
7.3 Rocket
Thanks, Ray. Saw that post shortly after I put this one up...
This one can be shut.
RBerry9511
Feb 7, 2020 04:31 PM
ssj7kids
13
May 6, 2008 11:09 PM
cowboy352u
May 19, 2007 07:37 AM
Beast12
Electrical Systems/Wiring
Jul 30, 2004 10:16 PM
