Spring ID Tag???
Old Sep 24, 2014 | 03:27 PM
Cj7clay's Avatar
Cj7clay
Spring ID Tag???
What size springs do I have in the rear of my Ex, I have looked everywhere and can't find this code CG
Old Sep 24, 2014 | 03:50 PM
jpr38057's Avatar
jpr38057
My catalog shows DG as the spring code. Like you, I'm not sure what the CG is.
Old Sep 24, 2014 | 03:51 PM
Cj7clay's Avatar
Cj7clay
Thats what I keep coming up with
Old Sep 24, 2014 | 03:56 PM
jpr38057's Avatar
jpr38057
I'm getting my information from the Ford parts lookup. I did it with your vin and without and both showed the same.
Old Sep 24, 2014 | 04:00 PM
Cj7clay's Avatar
Cj7clay
Must just be a typo
Old Sep 24, 2014 | 04:23 PM
mecdac's Avatar
mecdac
The following only applies to 4X4 EXs, the 2X4 rigs have coil springs up front. All EXs came from Ford with G code rear springs, the V-8 EXs all came with B (front B code is much different than rear B code, confused yet?) 4100lb, all V-10 EXs came with C code fronts at 4300lb and all PSD EXs had D codes at 4700lbs.
All the other codes discussed come from SuperDuty trucks (they came with springs that don't suck from Ford.)
Spring........Capacity.....Rate lbs/".....Max travel.....V-10 change.....PSD change
B (V-8)......4100lbs.......330 lb/".........5.02"...........-0.25".............-0.66"
C (V-10)....4300lbs.......350 lb/".........5.01".............0.00"............-0.37"
D (PSD).....4700lbs.......380 lb/".........5.14"...........+0.33".............0 .00"
S codes.....4000lbs.......370 lb/".........4.34"...........+1.22"............+0 .88"
T codes.....4400lbs.......390 lb/".........4.63"...........+1.42"............+1 .11"
U codes.....4800lbs.......410 lb/".........4.89"...........+1.60"............+1 .32"
V codes.....5200lbs.......430 lb/".........5.13"...........+1.77'............+1 .50"
W codes....5600lbs.......450 lb/".........5.34"...........+2.77'............+2 .52"
X codes.....6000lbs.......470 lb/".........5.54"...........+2.90"...........+2. 68"
W codes are from F-450s and X codes are from F-550s and other SD trucks with snow plow prep. The above spring info has been gathered from posts here on FTE
Old Sep 24, 2014 | 04:41 PM
Cj7clay's Avatar
Cj7clay
So whats the CG code?
Old Sep 24, 2014 | 04:52 PM
slowlanemcvane's Avatar
slowlanemcvane
C code front, G code rear?
Old Sep 24, 2014 | 04:55 PM
Cj7clay's Avatar
Cj7clay
Cant find a G code
Old Sep 24, 2014 | 04:56 PM
slowlanemcvane
Mecdac posted that all Excursions have a G-code rear, and that all V10 Excursions have a C-code front.
Old Sep 24, 2014 | 05:23 PM
Cj7clay's Avatar
Cj7clay
whats the weight of the G code?
Old Sep 24, 2014 | 05:41 PM
mecdac's Avatar
mecdac
5250 LB ten chars
Old Sep 26, 2014 | 04:11 PM
WE3ZS's Avatar
WE3ZS
Not enough!
Old Sep 26, 2014 | 06:58 PM
holeshotwalt's Avatar
holeshotwalt
You are correct, sir!
pkthomas
Apr 30, 2015 09:14 PM
GerritMaxwell
15
Nov 26, 2014 05:06 PM
wrxin
May 30, 2014 09:09 PM
blackford4x4
Sep 26, 2010 12:04 PM
