B code question
Old Aug 10, 2010 | 01:48 PM
blackford4x4's Avatar
blackford4x4
B code question
Got my v code springs installed last night, already seams to drive better raised it about 1.25". It actually sets about 1/2" higher in the back with the stock springs and RAS.
I am going to install the rear b codes this weekend... weather permitting. The B's I received from ford are a bit different looks like the modded b's already. I have a picture attached of spring front and rear part numbers just curious what i have and if i need to use the stock blocks or the 3.5 tapered (according to ford they are 3.65") This is NOT including the RAS i will play with it after to see what the springs do. Thanks
Also not sure what the upper leaf does it does not touch anything?!?!?!?!?
Old Aug 10, 2010 | 02:11 PM
Stewart_H's Avatar
Stewart_H
Part #2C3Z-5310-HA is the V code spring.
Part #3C3Z-5560-CB is the part number for the B code springs. Since the part number you have is Part #3C3Z-5560-CA, and the picture you've posted is a spring with an overload top spring, I'd assume your spring is the B code with an overload.
The B code part number ending in CB doesn't come with an overload spring.
Modded B's are only something produced by the end user by taking apart their OEM Excursion springs and adding certain pieces to the new B code spring.
Stewart
Old Aug 10, 2010 | 04:19 PM
blackford4x4
Thanks for the fast reply, so does the overload add any height, i see how the btm leaf adds weight capacity but clueless on the top spring.
Old Aug 10, 2010 | 04:55 PM
Stewart_H's Avatar
Stewart_H
You're not gaining any weight capacity with the springs, it just handles the weight better than your OEM springs, and gives you added height.
The overload spring doesn't add height. Your spacer block (tapered or OEM) goes between the axle and the bottom of the spring. The overload spring is just there to keep the spring from over-arching by contacting the bottom or the frame on big bumps.
Stewart
Old Aug 10, 2010 | 09:16 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
May I ask what's the cost for them V&B? in USA.
Old Sep 24, 2010 | 05:34 AM
cbpip's Avatar
cbpip
If you use the springs with overloads on the Ex you will damage the rear A/C lines. Need to remove the overloads before you install.
Old Sep 26, 2010 | 12:04 PM
Forest's Avatar
Forest
You also may not need the 3-1/2" tapered blocks if you use RAS. The RAS will raise enough that the stock 2" blocks will be about right. The only problem is driveline angle--you might cause rear end vibration.
On my 05, I have been using rear non-modded "B" springs with RAS and 2" straight blocks.
elgemcdlf
277
Dec 19, 2018 12:29 AM
sofob0909
Jun 14, 2016 02:50 PM
clintusaf
Feb 12, 2013 02:29 PM
jasoncw
Sep 30, 2011 06:18 AM
Waltdog
21
Mar 1, 2010 08:14 PM
