Adding two Fuel inline filters?
Old Sep 23, 2014 | 02:13 PM
CharlaineC's Avatar
CharlaineC
Ok so i need to replace the fuel line at the Aux and Main tank Diverter. I'm wondering what you all think about the addition or two small inline filters there. so that basically there is a filter for each tank then one for the main pump.
Old Sep 23, 2014 | 02:23 PM
51M1's Avatar
51M1
I would stick with the one in the engine bay. Easy access to change and no modification to fuel system in or under the cab. Safety issue.
Old Sep 23, 2014 | 02:24 PM
JEFFFAFA's Avatar
JEFFFAFA
My gut feeling tells me to Not do it. I am not the engineer type. Cougarjohn or Ultraranger may have better insight than me. There has to be a reason Ford never put a filter behind a mechanical fuel pump. I am assuming has something to do with either the pump's suction or air getting trapped in the filter(s) and impeding flow.
Old Sep 23, 2014 | 02:39 PM
HIO Silver's Avatar
HIO Silver
A pre-filter (with large orifices to catch large debris) in addition to a standard filter would be acceptable IMO.
Old Sep 23, 2014 | 10:31 PM
CharlaineC's Avatar
CharlaineC
Talked to the lead mechanic at the ford dealer up the road from me. he is the one who advised me of installing the two inline filters stating that it will help catch the rust and crap in the tanks until they're used to being run again. he said that I can keep them or remove them later on once junk is out. I'll try it and see how it goes for a few months then remove them.
Old Sep 24, 2014 | 04:56 AM
f100today's Avatar
f100today
There is no reason you can't put filters in that location. Probably a good idea if u have a dirty tank. However, I would spend a little money and put a reusable/cleanable canister filter in the single line.
Old Sep 24, 2014 | 07:11 AM
BobbyFord's Avatar
BobbyFord
I have a 100 micron fuel filter under the bed at the Mustang gas tank and a 40 micron filter just before the carb.
Old Sep 24, 2014 | 08:52 AM
ultraranger's Avatar
ultraranger
I had read some years ago that putting a filter in front of the pump (on carbureted engines, not fuel injected engines) increases the probability for vapor lock.
I don't know if that is fact but, in a carbureted engine, that part of the fuel line is under vacuum (and head pressure of the gas tank) with the fuel pump sucking the fuel from the tank to the pump.
In a fuel injected setup, the fuel at that point is roughly at 100 PSI with an electric fuel pump that's pushing the fuel, under pressure, from the tank to the injectors of the engine.
Old Sep 24, 2014 | 10:52 AM
CougarJohn's Avatar
CougarJohn
I can think of two reasons why Ford put the filter after the pump:
1) Changing a filter before the pump will lead to fuel being poured on the mechanic,
2) Placing the filter after the fuel pump will trap any debris from a decaying diaphram and keep it out of the carb.
I have always put one in both places.
Old Sep 24, 2014 | 11:12 AM
351Cleveland C4's Avatar
351Cleveland C4
I have a 20 micron see through plastic filter right before the pump, and the factory style gold steel 10 micron filter at the carb.
As long as you keep the pre pump filter clean you won't have an issue. However I would use just one filter under the hood. Easier to change and will do the same thing.
Biohazard74
Jan 31, 2019 11:07 PM
BeerKnurd
Nov 9, 2011 07:53 AM
Bronco86
Feb 15, 2004 01:06 PM
Bronco86
Jan 2, 2004 01:45 PM
GeneStoner
Jan 13, 2003 07:22 PM
