The guy has an extra flywheel and clutch but no transmission.
What are my options? I am pretty sure the manuals from any Modular Ford may work, but do not know. Finding a proper trans for it has been harder than expected. 4X4 transmissions seem pretty common.... but as this will be a lowered truck I think a front diff might be kinda hard to tuck in there.
All the International 6.9/7.3 diesel engines that went into Ford trucks (6.9 IDI, 7.3 IDI, 7.3 IDI-T, 7.3 PSD) have the same bolt pattern. It is not the same as any Ford engine bolt pattern. The PSDs were originally mated to ZF-5 transmissions; that would be the simplest solution.
I need an Fuel Injection Control Module. I was talking with a local diesel guy who says the newer post 97 modules will work for me. He has one. My question is basically.... will it. He says it will use a higher voltage than stock, but that should not matter and will work fine. It is meant to fire the split fired injectors.
Thank you. That was what I was to understand. Guy said a high voltage would reduce knock a bit..... which is actually the opposite of what I want in a gnarly old Ratrod. But I need running.
