7.3 Engine swap idea
Old Oct 11, 2010 | 05:33 PM
BLK SHP's Avatar
BLK SHP
I have a ford f-150 1996 with a 302 and i want to put a 1990 7.3 IDI diesel engine in it thats out of a ford f-350. I have a five speed manual in my truck rite now and am wondering if it would bolt up to it or if i need a new trans, and if so what trans should i get(preferably a manual). Also for this swap what all would i have to do to my truck.I have been reding some other guys ideas about diesel swaps and some say cummins or inline 4s, were can i find theas engines, and wats there cost
Old Oct 11, 2010 | 06:02 PM
starmilt's Avatar
starmilt
No gas tranny will bolt to the 6.9 or 7.3, you will need the zf5 tranny from a 7.3.
Old Oct 11, 2010 | 06:56 PM
BLK SHP's Avatar
BLK SHP
Is that zf5 trans a manual?
Old Oct 11, 2010 | 07:21 PM
oreocreaming's Avatar
oreocreaming
yes, zf5 is 4 standard gears and a overdrive in place of 5th gear.
Old Oct 11, 2010 | 07:22 PM
oreocreaming
and you can use a gasser zf5, BUT you gotta redrill the bell housing on it to match the bolt pattern.
Old Oct 11, 2010 | 07:24 PM
oreocreaming
Ford Truck Enthusiasts Forums - View Profile: kenpobuck talk to him. hes got a bronco that he swapped a idi into. he'll be the most help on the subject of swappin diesel into 1/2 ton
Old Oct 12, 2010 | 08:33 PM
BLK SHP's Avatar
BLK SHP
Ok thanks I am kinda interested in a four cylinder cumins or somthin similar to that the7.3 is a heavy engine.
Old Oct 12, 2010 | 08:40 PM
oreocreaming
ya, 1000lbs or so for the engine. 1200 loaded
BiltFordTuff
Jan 4, 2020 09:24 PM
Shwan_89HD
15
Jan 24, 2012 09:43 PM
BLK SHP
General Diesel Discussion
Oct 22, 2010 01:07 PM
fnasausage
Feb 12, 2010 02:03 PM
powvey
Sep 24, 2004 08:56 PM
