Brake hard-line replacement
Old Sep 22, 2014 | 09:28 PM
meangreen92's Avatar
meangreen92
Howdy. My buddy just got a 1996 E150 (standard wheelbase I guess) and it sounds like it's going to need new hard-lines for the braking system.
I searched and found one thread here, which shed some light.
Is there anything special I need to know?
I haven't looked at it yet, but I imagine we'll just get universal line segments, with the flares and nuts already there, and bend to fit.
Thanks.
Old Sep 23, 2014 | 07:21 AM
Wildman25's Avatar
Wildman25
You could go with the 'pre-made' brake lines
Quick search found this link-
https://www.ford-trucks.com/forums/9...rake-line.html
Good link, with pictures too.
Me, I've been that route before, Now, I get a roll (25ft) of coated 3/16" steel line, bag of 10 short 3/16" x 3/8" hollow nuts, and make my own lines.
Cost = coated line is about $1 /ft, nuts are less than $9 for 10.
Compare that to pre-made line.
Replace everything, from master cylinder, and all soft lines too, and at the age of that van (18 years old) I would also replace the wheel cylinders.
In other words, replace everything at once, and trouble free for years to come.
Is this over kill, Yes, it's a full days job, and with everything getting replaced, and one time bleeding the system, your done with any additional leaks, or problems.
Just make sure you double flair all fittings, that is a must.
This link shows the "new" Napa flaring tool -
https://www.ford-trucks.com/forums/1...eplacment.html
Old Sep 23, 2014 | 07:00 PM
meangreen92
Thanks Wildman25!
Perfect links. I swear I searched "brake lines" on this site and found one relevant thread from a few years ago, but not the one from one month ago...
It probably would be better to just get a roll of tubing and the hollow nuts, and "rent" the flaring tool from the McParts store.
I did mention the flexible rubber lines to the owner, and will mention the wheel cylinders.
I'm definitely all for bleeding it one time only.
Old Sep 24, 2014 | 05:31 PM
maples01's Avatar
maples01
My 40 year old van has good steel, the rubber, that was the problem, it wouldn't allow the rear the required pressure for braking, it was seized to the line nut too, wound uip destroying it, had to cut the steel line and reflare it to attach my new rubber.
Old Oct 15, 2014 | 04:30 PM
meangreen92
OK, I got the line and the fittings, he brought the van over, I got under it, and found ABS! 4 Wheel ABS!!! It's a '96 Tradewinds conversion.
I googled it, and decided that I'd better leave it alone, as I don't have a scan tool for the ABS module, and I've never had or worked on ABS or even an OBD2 vehicle.
Am I right to chicken out on this job?
It sounds like if air gets in that ABS module, that it won't let any fluid through, hence no brakes. So it would have to be towed to a shop to bleed out the ABS properly?
Krindgen
1997 - 2003 F150
May 23, 2011 05:58 PM
64F260
13
Mar 5, 2007 10:24 AM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
15
Oct 3, 2006 04:47 PM
army_guy25
Aug 30, 2006 05:44 PM
WoodN1_76
24
Jun 23, 2003 09:18 PM
