one of my knuckle was expand due with a bolt nut tight....
so i read about a insert sleeve repair but i just see for dana 60 gm....nothing about ford...so maybe somebody can help me...thanks
the tie rod end hole on my knuckle is oversize so , i search for insert sleeve to repair that but all i read is for dana 60 gm .... i know the ford hole size is 5/8 little hole and big is 3/4....where can i buy one for ford...
so i can oversize the hole with a reamer and buy a chevy tie rod end or
oversize the hole with a 7/8 bit and buy a insert sleeve and buy chevy tie.. too
but the size of the chevy tie rod tread are the same of the ford f350 ...i can tread in the direction bar.....
