Sponsored by: Kumho
tie rod hole egged
Old May 12, 2007 | 03:37 AM
greythorn3's Avatar
greythorn3
tie rod hole egged
Vehicle
1986 f350 CrewCab 6.9 diesel C6 dana 60 front stearling 10.25 rear axle
I replaced the tie rod s and drag link and cant get the drivers side tie rod to tighten in the knuckle.. its egged out... is there a fix or somthing to this problem without replacing the knuckle???
Ray
Old May 12, 2007 | 07:02 AM
arctic y block's Avatar
arctic y block
I've tried bushing that Ray but it didn't hold as I used brass. I'd replace it. Not that big a job. A Machine shop can weld it up and redo it as well but a used one would be cheaper.
Old May 12, 2007 | 11:51 AM
75F350's Avatar
75F350
Not sure what the term "edged" is, but I am assuming that the hole is no longer round.
I had a truck at the shop that had a similar problem, and I made a larger tappered hole and used a slightly larger (G.M.) tie rod end. Easy to do, if you have the tool to make the taper.
I have also seen the holes drilled out, and use rod ends.
How tall is your truck? Is it time to do a complete crossover steering, and maybe a highsteer? might be cheaper in the long run. This would be a good time to upgrade instead of buying the same stuff, you could apply that money to a nice modification.
Old May 12, 2007 | 03:31 PM
kotzy's Avatar
kotzy
Are you sure you have the right part, if the taper is to long the nut will bottom on the threads and it won't tighten. I have seen this on ends as well as ball joints, if it was tight before how would it have changed? Check that part! My advice.
kotzy
Old May 12, 2007 | 04:52 PM
greythorn3's Avatar
greythorn3
thank for replys
no it was lose before.. i thought it was the tie rod but it was the hole... so i shimmed it with washers to tighten it in the over sized hole and it worked for about a mile.. and its loose again.. do yuou have the specs (like degrees?) on the GM TAPER? i could get a gm tierod and taper the hole bigger..... my truck is stock height. stock suspension.. i could not fit crossover steering on it..
if all else fails i will have to heim joint it i would rather have a tie rod though..
ray
Old May 14, 2007 | 04:25 AM
greythorn3's Avatar
greythorn3
just for the record
I have been told to use a chevy tie rod end as it is bigger.. the tapered reamer size is 1.5" per foot.. so if anyone else is looking to repair worn holes here is the solution..
Ray
Old May 14, 2007 | 04:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Why not weld up the hole and then re-drill it to the correct size.
Old May 14, 2007 | 07:36 AM
greythorn3's Avatar
greythorn3
larger
The larger taper of the gm tie rod is more desirable im told.. it isnt supped to wear out as easily
Ray
bigcrunch
Apr 11, 2016 10:54 AM
ved0303
Sep 28, 2015 10:28 PM
bryanmartin
Jul 27, 2015 07:06 PM
77highboy77
May 10, 2015 05:46 PM
mikecox1
Apr 6, 2009 04:03 PM
