Shift boot
Old Sep 22, 2014 | 07:49 PM
ige1963's Avatar
ige1963
Shift boot
63 flare side, 4 on floor - did this truck have a boot on the shifter? If not, I think one would look ok - any suggestions? Thanks in advance.
Old Sep 22, 2014 | 11:25 PM
TBird Larry's Avatar
TBird Larry
A shift boot takes the fun out of driving an old truck! You'll miss the noise and the smell of the oil and exhaust smoke not to mention the heat in the summer or the freezing cold in the winter.
Shift boots are available from the online catalog guy's of your choice. They don't cost a bunch either.
Good luck...
Old Sep 23, 2014 | 02:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
63 flareside, Borg Warner T-98 4 on floor - did this truck have a boot on the shifter?
No.
None listed for the T-98 4 speed in the 1957/63 & 1964/72 Ford truck parts catalogs. I looked in Carpenter's 1957/66 truck catalog, none listed there either.
Old Sep 23, 2014 | 05:41 AM
TBird Larry
There is a thread from 2013 on the shifter boots, use one from a later model into the 70's. https://www.ford-trucks.com/forums/1...fter-boot.html
JC Whitney has some but they are universal.
Some on eBay also here...ford truck shifter boot | eBay
Good luck
Old Sep 23, 2014 | 10:13 AM
dragonballs's Avatar
dragonballs
4wd Low
you can have a local upholstery shop make one for you.
Old Sep 23, 2014 | 01:52 PM
ktnissen's Avatar
ktnissen
My 64 does not have a boot either, I don't even have holes thsin the would hold the boot in place on my floor.
Old Sep 23, 2014 | 03:11 PM
schoo's Avatar
schoo
this is what my t98 looked like
it kept the snow and rain out
Old Sep 23, 2014 | 07:48 PM
ige1963's Avatar
ige1963
Merci beaucoup!
Thanks for info - I think a generic product will work. Btw - I'm almost ready to post pics of my f100 - as soon as I get the wheels back on!
Old Sep 24, 2014 | 12:33 PM
NumberDummy
Originally Posted by schoo
this is what my t98 looked like, it kept the snow and rain out.
1961/64 F100/700 with Warner T-98 4 Speed:
C0TB-8112130-A .. Transmission Cover Weather Pad / 2" I.D. x 7" O.D. x 2" thick / Obsolete
C1TB-8112130-A .. Transmission Cover Weather Pad / 3 3/8" I.D. x 7" O.D x 2" thick / Obsolete
No Ford dealer or obsolete parts vendor has either type.
Old Sep 24, 2014 | 12:51 PM
schoo's Avatar
schoo
I use a foam block on it now with a rubber grease cap over the shifter ball
the guy I bought it from said it was off a f600? no part #
Old Sep 24, 2014 | 01:05 PM
NumberDummy
I use a foam block on it now with a rubber grease cap over the shifter ball, the guy I bought it from said it was off a f600? no part #
F100/700 = parts catalog speak for: F100/250/350/500/600/700.
pchelp
Jan 10, 2018 02:42 PM
foreman400x
Appearance & Dress-Up
Mar 21, 2008 06:54 PM
BIIman
Nov 21, 2006 12:43 PM
Warhorse86
Jan 31, 2004 09:24 AM
