7.3 wire short
Old Sep 21, 2014 | 08:58 PM
efcfarm's Avatar
efcfarm
7.3 wire short
I have a 1989 f 250 that randomly shuts down. While investigating, I found a rat's nest near firewall on drivers side. Now the red with green stripe fused wire on passenger side that goes to the injection pump is shorting out (smoke). What is causing this? I think I found all of the bear wires and insulated those. Btw new member and new to me truck. Thanks for the help
Old Sep 21, 2014 | 11:37 PM
Red454sedgwick's Avatar
Red454sedgwick
that's your trigger wire to tell every thing your key is on, I would jump a wire with a fuse on it from your battery straight to your pump with the green red unhooked. if you blow your fuse the short is in the pump, if not it is in your harness.
Old Sep 22, 2014 | 06:52 AM
efcfarm's Avatar
efcfarm
Thanks I'll try that first
Old Sep 22, 2014 | 01:25 PM
efcfarm's Avatar
efcfarm
Everything is ok with injection pump solenoid. Now I am leaning towards gp. Started smoking by gp engine temperature sensor. Can it short out? Or is it in the gp controller/relay?
Old Sep 22, 2014 | 07:21 PM
Red454sedgwick
they can any wire can short out
86Justin
Jan 8, 2016 03:00 AM
sean9049
Feb 26, 2015 03:23 PM
muscletruck7379
Oct 6, 2010 09:31 AM
fordmudrunner2020
Feb 27, 2004 08:35 AM
fordmudrunner2020
Feb 26, 2004 11:39 PM
