Anyone ever have this steering issue?
Old Sep 21, 2014 | 11:38 AM
alloro's Avatar
alloro
2001 Navigator 5.4 4WD.
While driving down the road it feels like the steering wheel is ever so slightly fighting me when moving it to the left. It's like when I'm riding the right edge of a lane and go to move the wheel slightly left to move to the center of the lane, the steering wheel doesn't want to move. Give it just a hair more pressure and it moves. No problems in the opposite scenario of going to the right. Then while going straight it will without warning at any random moment it feels as if someone grabbed the steering wheel and yanked it an inch or two to the right or left.
Anyone ever experience this, it's a new one on me.
Old Sep 21, 2014 | 12:38 PM
halofive's Avatar
halofive
Check your ball joints and all moving steering parts on that side. It sounds like a bushing or joint is bad. Looks for slung grease and cracked/missing boots on the joints.
Old Sep 21, 2014 | 02:21 PM
alloro's Avatar
alloro
Thanks, been there done that. I'm leaning toward a leaking seal inside the steering gear as a possibility. But I was hoping some here experienced this and could provide some insight.
Old Sep 24, 2014 | 01:51 AM
crazy96863's Avatar
crazy96863
As you suspect... Rack and pinion assembly. Maybe a seal. Maybe a valve. Can't be certain. Just replace it; you will spend less time, headache & $$$ when its all said n done. These aren't easily diagnosed or repaired without specialized equipment most repair shops don't have because replacing is cheaper.
Old Sep 24, 2014 | 08:18 AM
pdqford's Avatar
pdqford
No R&P. Its a 2001.
Old Sep 30, 2014 | 07:10 PM
albtrossca's Avatar
albtrossca
Mine is doing the similar thing. Found the coil spring busted on the passenger side. Haven't changed it yet but it drops that side a bit which I am assuming will change the camber and alignment. A broken spring is hard to see unless you look carefully.
I hope this helps.
Old Oct 3, 2014 | 05:46 PM
albtrossca's Avatar
albtrossca
I hope this helps.
Changed the spring in the shock and the steering is much better. Unfortunately while I was under there i found the u joint buggered in the shaft from the transfer case to front axle. Grrrr!
Old Oct 3, 2014 | 06:36 PM
alloro's Avatar
alloro
It'll end sometime.
Old Oct 3, 2014 | 09:38 PM
albtrossca's Avatar
albtrossca
Did you resolve your steering problem?
Old Oct 4, 2014 | 12:26 PM
alloro's Avatar
alloro
No I haven't dug into it yet. The wife has been driving it every day so it hasn't been available to me, so in the meantime I'm researching possible causes.
Old Oct 5, 2014 | 07:39 AM
albtrossca's Avatar
albtrossca
I changed my coil spring and the steering is back to normal. U joints changed too. Now i just have to solve the transmission shift solenoid A code.
Old Oct 5, 2014 | 08:16 AM
c_hohensee's Avatar
c_hohensee
It sounds like a problem I had on a 79 Bronco. It was the steering gearbox. I ended up picking up a rebuilt unit to fix it.
Old Oct 6, 2014 | 11:50 AM
expeditiongrrl's Avatar
expeditiongrrl
Had similiarly described issues on a F150 was the tire of all things.
scsi6
Jan 14, 2016 11:14 AM
XLnAK
Sep 6, 2015 12:06 PM
smashclash
32
Dec 29, 2010 11:30 AM
89Bulldog
1983 - 2012 Ranger & B-Series
Jun 15, 2010 10:04 AM
bonecarver
May 3, 2007 04:10 PM
