Codes
Old Sep 19, 2014 | 01:28 PM
kbf1961's Avatar
kbf1961
Codes
Whats the easiest way to check codes on this 6.0. I have a scangauge11. Will that check codes?
Old Sep 19, 2014 | 02:44 PM
87crewdually's Avatar
87crewdually
SGII will check codes. With it plugged in, turn it on with key on engine off, and hit the SCAN button. It should reveal if any codes are present on the next screen.
Old Sep 19, 2014 | 02:54 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Scangauge is hit or miss on displaying some trouble codes. Here is a x-Gauge code for DTC count. If it shows three (for example) and you only get one code with the scan button you know you have two more "lurking" in there and may need a better scanner to retrieve it. Most of the parts stores will scan for free, depending on which model of scanner they have on hand it may pull any remaining codes.
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Old Sep 19, 2014 | 02:59 PM
kbf1961's Avatar
kbf1961
I seem to remember hearin somethin about an I phone app you can read codes with? Would you happen to know anything about that?
Old Sep 19, 2014 | 03:03 PM
87crewdually
Torque app and a bluetooth to OBDII adapter for android from Amazon.
Old Sep 19, 2014 | 03:06 PM
kbf1961's Avatar
kbf1961
Thank you.
Old Sep 19, 2014 | 05:36 PM
Rusty Axlerod
The iPhone app is called DashBoss.
Here is some more info: https://www.ford-trucks.com/forums/1...eral-info.html
Old Oct 17, 2015 | 10:05 PM
Remmons's Avatar
Remmons
Expedition 2011 Limited
Last edited by Remmons; Oct 17, 2015 at 10:07 PM. Reason: Removed post wrong thread!
ldunston7621
Apr 24, 2015 01:42 PM
tonefordays
Feb 27, 2012 02:49 PM
czabala
Computer Chips & Tuners
Sep 14, 2004 01:18 PM
strokeman
Aug 27, 2003 10:36 AM
