A/C clutch cycle
Old Jul 14, 2003 | 05:56 PM
Copper93's Avatar
Copper93
Question A/C clutch cycle
I read the other post and need something cleared up. I had my 1990 Bronco converted to R134a and the compressor does not cycle anymore. Is this normal? Before it was converted the compressor cycled regularly. The low side pressure is 45, I don't know the high side pressure.
Old Jul 14, 2003 | 07:28 PM
steve83's Avatar
steve83
A/C clutch cycle
The clutch only cycles if the pressure gets low (because there's not enough heat left in the air passing the evaporator) or because there's a leak. That keeps it from ever pulling air INTO the system.
It may be that there are leaves blocking your evaporator or some problem with the system, but the lack of cycling isn't necessarily a problem in itself.
You can pull the blower motor & reach in here to feel if there are leaves. If there are, pull the evaporator cover as shown (you won't be opening the refrigerant system so don't worry) and hose it out.
Old Jul 14, 2003 | 07:37 PM
Copper93's Avatar
Copper93
A/C clutch cycle
Thanks, I'll check it out.
Watcher58
Mar 31, 2017 11:23 PM
02expy
Jun 29, 2016 03:52 PM
mushman
18
Aug 3, 2015 07:54 AM
tp4pdb
Aug 17, 2008 10:36 PM
jims89bronco
Apr 13, 2004 01:30 AM
