hissing noise
Old Sep 18, 2014 | 09:23 PM
valfaro4's Avatar
valfaro4
hissing noise
I replaced egr cooler and a oil cooler on a 2006 f250 and after I finished I noticed a hissing noise coming from the right rear of the engine, I test drive and also noticed slow response on acceleration. Engine is smooth as silk and not misfiring. When I first start engine for the first 5 seconds hissing noise is not there then I start to hear. Also checked for codes and none present. Any ideas? I'm thinking a leak at one of the turbo flanges but not sure.
Old Sep 18, 2014 | 09:28 PM
22fordguy's Avatar
22fordguy
bad seal on your up pipes some were start with the egr cooler connection and turbo connection.
Old Sep 18, 2014 | 09:59 PM
Yahiko's Avatar
Yahiko
Did you have any problems getting any of the flanges to mate-up?
The other thing if you really pulled may be a Y-pipe crack.
With a string on a stick and a flashlight you can snoop around all
the connections and not get burned as it heats up to look for a leak.
Sean
Old Sep 18, 2014 | 10:00 PM
valfaro4's Avatar
valfaro4
Now when you said up pipes is it the ones that connect to the turbo?
Old Sep 18, 2014 | 10:16 PM
Yahiko's Avatar
Yahiko
Yes.
They come from the exhaust manifold up to the Y-pipe and then
into the turbo.
Sean
Old Sep 18, 2014 | 10:53 PM
valfaro4's Avatar
valfaro4
Yes,I had to fight the turbo to get it to line up on the drivers side. The right side seemed to line up nicely.
Old Sep 18, 2014 | 11:05 PM
Yahiko's Avatar
Yahiko
Check around all the fittings. You may find
that one will be leaking.
When I put everything back on I had both of the
up-pipes loose at the exhaust manifold and installed
the turbo first but left the 3 bolts loose and went on
to the clamps. They slipped right into place without
yanking on them. after I got that all torqued I did the
3 turbo hold down blots and finished up with the up-pipes.
When I started I did not have any leaks.
BTW the shop workbook also says to do it this way.
Sean
Old Sep 18, 2014 | 11:20 PM
valfaro4's Avatar
valfaro4
Awesome, I will reinstall in that order. Now should a get new flange gaskets or reuse the old ones.
Old Sep 18, 2014 | 11:34 PM
Yahiko's Avatar
Yahiko
The EGR one most likely will be ok so long as
you were not pulling with the clamp to get it into place.
And like I said find the leak first then you know how far
you may need to go.
Sean
Old Sep 18, 2014 | 11:52 PM
valfaro4's Avatar
valfaro4
Ok, thanks you for your help.
Kcman116
Jan 2, 2017 10:35 PM
mwoolard1912
Jan 9, 2016 03:55 PM
mynameismyles657
May 10, 2011 03:19 PM
06silvercrew
Feb 16, 2010 08:23 PM
kpmurfy15
Mar 20, 2008 08:01 PM
