I'm new on here and i just purchased my dream truck! 1950 F6! It hasen't ran in 5 years. So i bought a battery and tried to start it up. The starter solenoid just made a clicking/buzzing sound. So i bought a replacement and now there is nothing. No sound or action. This is my first crack at doing a whole project and am looking for some help.
Welcome! Might be best to do an overall assessment before drilling down.
Look over the electrical system and determine if it is 6v or 12v. If it is 6v, clean every ground and starter connection. Look over the ignition wiring system to assess integrity - original, cloth insulation can be damaged by critters and time. Resist the temptation to replace stuff without a diagnosis. Be systematic in your approach and use an electrical tester to check connections.
If the battery has 3 caps or if a single cover and you pry it off, 3 openings. If it has 6 then it is 12V. Batteries are usually marked for voltage. The solenoid grounds through it's mounting point, make sure it is grounding correctly. From your original description the first two things I would check is, 1 battery state of charge (is it low),2 connections loose, dirty or corroded. I repair electrical problems on a daily basis, 95% are caused by one of those two things.
I agree, low or bad battery, bad battery post connection, loose or dirty.
If the new battery was on the shelf over a certain period of time it could be low on charge.
One other suggestion, because you said on intial try that the starter clicked than hummed. Suggests that the starter heated and than shut down, did it try to start after a period of time. Try turning the motor over by hand to make sure the motor has not seized from sitting for five years.
It's good practice to charge a new battery before installation. Oh, the clerk will tell you it's charged up and ready to go, and it may even start the truck. Charge it up anyway. A brand new battery is "hard" and will take a dozen or so starts to reach full capacity as well.
X2.....make sure the motor turns over first. Also the starter could be bound in the flywheel ring gear. Thirdly, the "replacement" solenoid may not be the correct one.
OP suggested that the battery is new. Clean all grounds and connections ensuring that the correct terminal is grounded.
Had a customer with a no crank condition a few months back. Took me 5 minutes to determine it was a bad battery. Called the customer to let him know what I found. He said battery was less than a week old. I installed a new battery, engine fired right up and customer returned the old/new battery to where he bought it. Just because it is new doesn't mean it is good. We have seen plenty of instances on this board lately of brand new condensers, coils,solenoids and other parts being bad out of or shortly after being removed from the box.
There are those that throw parts at a problem. Then there are mechanics that diagnose a problem and replace the part that is bad.
Motor will turn over by hand. It was the solenoid that was buzzing and clicking. I am going to clean all posts and grounds and see if that makes a difference.
You said the truck has not run in over 5 years. Are you sure the engine is not frozen / stuck? Have you actually been able to turn it by hand without using the starter/battery?
Anything older than say 10 or 20 years benefits from new battery and starter cables, engine to firewall, etc., too. They corrode at the crimp and inside under the insulation.
