starting system
Old Dec 3, 2001 | 06:31 PM
JoDanna _74's Avatar
JoDanna _74
Post starting system
Here's the prob: I've changed the solenoid, starter, & the battery. It was running fine & then when I went to start it up, the starter wouldn't disengage.I then replaced the voltage regulator but I'm still not getting any power (not even the clock mounted on the dash). Any suggestions?
Old Dec 6, 2001 | 08:57 AM
Mikeman's Avatar
Mikeman
starting system
Have you checked the battery cables? Sometimes, corrosion can occur inside the insulation and an otherwise healthy looking cable can be bad.
Old Dec 6, 2001 | 08:51 PM
badranger302's Avatar
badranger302
starting system
