Sponsored by: Real Truck
engine startup pre-luber ---- anyone have/try
Old Sep 18, 2014 | 05:50 PM
speakerfritz's Avatar
speakerfritz
anyone out there have one of these installed?
AutoEngineLube Prelube System Reduces Engine Wear Up To 60%
4 models to choose from....it will circulate some oil back into the system once the key is turned ahead of the oil pump pressure.
just wondering is the path of least resistance would be to back flush the oil filter rather than to pre lube all the bearings in the crank case. maybe no backflush is possible with a motorcraft filter with the rubber reverse flow valve.
eef350
6.4L Power Stroke Diesel
23
Nov 20, 2017 01:58 PM
Rasputin53
15
Nov 11, 2015 12:32 PM
thedaddycat
Feb 22, 2008 02:21 PM
wunderhill
Oil & Lubrication
Nov 29, 2007 12:04 AM
68torino
Oil & Lubrication
Feb 13, 2004 09:56 AM
