'91 f150 Ignition
Old Jul 14, 2003 | 04:04 PM
bab0711's Avatar
bab0711
'91 f150 Ignition
Help! My '91 F150 with 175,000 miles is acting weird. Have lots of "slop" in the ignition switch and I am intermittantly losing power to my radio, wipers, elect. windows, and the anti-lock light comes on. Motor keeps running though. I can jiggle the ignition and everything works until the next bump. I replaced the actuator rod about a year ago (christ what a job!). Truck won't start with the tilt wheel up but works just fine if you pull it down a couple of clicks. Am I looking at replacing the key switch or do I have additional actuator problems?
Old Jul 14, 2003 | 04:32 PM
steve83's Avatar
steve83
'91 f150 Ignition
It could be the switch (pretty easy to swap out) or the "actuator" which is 2 pieces of cast pot-metal that commonly break on pre-'92 tilt columns. Fortunately, they're not very expensive from Ford (~$45 for both). Unfortunately, they're nothing but a PITA to change out because you have to disassemble the steering column to do it. I've never seen a photo article on the process, and the last time I had to do it (~8 years ago), I didn't have a digital camera. If I ever do it again, I'll be sure to add it to the other ones in my signature link.
Until then, this is the best I've found. It came from this link.
BuckHunter1960
May 22, 2016 03:47 PM
shotgun64
Aug 26, 2015 05:14 AM
Paredez
1997 - 2003 F150
Jun 9, 2012 09:03 PM
Bandit91
Mar 12, 2012 11:36 AM
DBGrif91
Dec 25, 2011 11:55 AM
