Sponsored by: Real Truck
Changing wheel size?
Old Sep 15, 2014 | 10:57 PM
the_auto_tech's Avatar
the_auto_tech
So, with having figured out that I would be best sticking with a 35" tire at the tallest and a 4" lift to keep the truck all around useful, I am trying to determine if I should maybe change wheel size. Currently I have a 4.5" Rough Country lift along with 35x12.50x18 Goodyear Duratracs and 18x9 Gear Dominator wheels with 0 offset and 5" backspacing. Sometimes I look at the 12" wide wheels but find that only a couple companies like Fuel and Weld Racing make them. I'm wondering if maybe I should go to a 20" wheel, but that would mean buying a new set of tires and these are only about a year old with 8,000 miles.
Is anyone on here running a 18x12 wheel with a 35" tire on a 05-07 F-250? My biggest question is clearance issues. I know that the 35x12.50x18 will work perfectly on that wheel, but am unsure if you'd run into issues hitting the radius arms or sway bar.
Old Sep 17, 2014 | 01:49 PM
Psyclopse's Avatar
Psyclopse
I think it would depend on the wheel specs- such as where on the wheel the additional width is. If the distance between the lug face and inner rim edge is the same as your current wheel (meaning, the added width is all on the "pretty side"), your clearance on the suspension side wouldn't change any.
Old Sep 19, 2014 | 09:39 AM
the_auto_tech
Yea, that makes sense. I believe that's how most of the wider wheels are set up is that the extra width just adds to the "lip" of the wheel. Like I said, I know that the 35x12.50x18 will work just fine on the 12" wide wheel as it seems that's what most people run on them. I'm just not wanting it to look like the wheels are sticking out too far. I've got pocket-style flares, so I'm guessing it won't. An 18x12 just looks meaner. Also, I'm curious if it will affect snow or off-road traction as well.
Old Sep 19, 2014 | 08:00 PM
Psyclopse's Avatar
Psyclopse
It will probably affect traction in the snow. Trucks like a tall and skinny tire best in snow. It'll mostly depend on your tires though. Big mud tread isn't the greatest in snow.
Old Sep 23, 2014 | 12:20 PM
the_auto_tech
Like I said, I currently have 18x9 with 35x12.5x18. I guess it really wouldn't change traction much just because you're using the same size tire, just stretching it out a little bit. Using Goodyear Duratracs.
Anyone on here running an 18x12? I'm wondering if I would be best going to a 20" wheel setup.
Old Sep 23, 2014 | 01:25 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
12" is too wide. You want a 20x10 or 18x9
Josh
Old Sep 23, 2014 | 01:29 PM
the_auto_tech
Why is it too wide?
Old Sep 23, 2014 | 02:51 PM
Bullitt390's Avatar
Bullitt390
12.5" tire on a 12" rim? It will look like a Vato truck... Might as well makes those wheels gold 100 spokes too.
Josh
Old Sep 25, 2014 | 11:48 PM
the_auto_tech
I guess you're right. I wonder if I would be happier with a 20x10 with a 35x12.5. That would involve about 2000+ dollars though.
Old Sep 26, 2014 | 12:11 AM
Bullitt390's Avatar
Bullitt390
Crazy how much that stuff costs!
Being mine is an XLT I originally had 17" wheels. I really liked the 08+ Lariat 18" wheels, and also the different styles of 20" King ranch wheels.
Glad I went with the 18" Lariats, tires are way cheaper. Currently have about 35K on my 275/70-18 BFG Rugged Terrains and more than half tread left.
For a 12.5 tire I think for a daily driver a 9" wheel would look best. For major off-road I would I even consider an 8" for more sidewall flex.
Josh
Old Sep 26, 2014 | 01:24 AM
Mcrafty1's Avatar
Mcrafty1
Josh
Sorry for the hijack..........did changing your wheel size from 17 to 18 inch effect your trans shift strategy or your Spedo accuracy much? and if so how did you correct this? Thanks in advance.
Old Sep 26, 2014 | 06:29 AM
Bullitt390's Avatar
Bullitt390
I corrected the speedo with an SCT Tuner. Calculated tire revs was 608, I use 638 revs to be accurate with a GPS.
Josh
Old Sep 26, 2014 | 01:56 PM
Mcrafty1's Avatar
Mcrafty1
Josh
Thanks, Did correcting the speedo also correct the shift points or where they ever an issue before you corrected the speedo?
Also since I don't have a tuner do you know if I can go to a Ford dealership and get my speedo re-calibrated and deal with any transmission shift point issues that the swap may bring on? Thanks for your help.
Mitchapalooza85
Feb 24, 2019 02:54 PM
Wrench_it
Jun 26, 2017 12:49 AM
D & D
Offroad & 4x4
Feb 8, 2016 03:15 PM
Almost_A_Merc
Jun 13, 2005 01:36 AM
Knobby4604X4
May 23, 2003 01:37 AM
