Post Trip Performance Results from my 6.4
I just returned from a 4000+ mile western US trip in my (new to me) 2008 6.4 F250. I was pulling a 33' fifth wheel weighing in at around 14000 lbs. The truck has been modified with a H&S Minimaxx tuner, DPF delete, and a Banks cold air intake. Overall, the truck ran great and got an average of 11.5 MPG while pulling the camper.
A couple of issues did arise. About 2/3rd's into the trip, the truck developed a coolant leak that I've since diagnosed to a upper main hose connection (where it connects to the engine). I had to add coolant several times during the last 1,000 miles into the trip although the engine never overheated; it just leaked. Thanks to this site, I've pulled the TSB on the single O-ring hose connectors and understand those need to be replaced. While reading about what that means, I found information on removing the EGR cooler to further improve performance and create some space under the hood. I'm not sure what all's involved with doing that; how expensive a modification is it and what are the +/- of doing it? I'm fairly handy with a wrench but have no idea how extensive that change is.
Secondly, the cruise control began operating intermittently. Sometimes it worked and sometimes it didn't. Again, this site says it's most likely the switch attached to the underside of the brake master cylinder. Does anyone have experience with that particular problem and what fixed it?
Lastly, I'm new to diesel powered vehicles. What do I need to know to keep my truck running well? I understand oil changes per the severe service schedule and fuel filter changes every 20,000 miles, but what other things do I need to be looking for especially given the modifications that have already be installed?
Any help is appreciated; thanks in advance!
Good luck with your F250, I have an 08 F350 SRW. This is a good forum with good feedback for questions and or issues.
Oil at 5,000 mile intervals & Fuel filters at 10,000 mile intervals.
Check fluids regularly. I pop my hood nearly every time I fuel to check coolant. Great piece of mind. Keep an eye on oil level and run CJ4 approved oil. Only Racor or Motorcraft filters. Periodic oil analysis is a great idea as well.
The pressure switch on the bottom of the master cylinder(towards front)....is most likely what's cause your cruise not to work. It's easy to replace...just disconnect the wiring harness, remove old switch and install new switch. You'll only lose a drop or two of brake fluid, and you don;t need to bleed anything after either. Hardest part is getting your hands in there to do it. Some say to remove drivers side fender splash lining to do it.....I just reached in and did it...took about 15 mins.
wakeupluis
04-01-2012 10:21 AM
bluepsylo
General Automotive Discussion
30
01-19-2009 06:52 PM
skibender2
02-12-2005 05:13 AM
