No start
Old Sep 13, 2014 | 05:37 PM
chromeLuxx's Avatar
chromeLuxx
No start
My 68 f100 original 360 w/electronic ignition sits alot, but the battery is relatively fresh and meters good. Drove it the other day a couple of miles and back just fine, but the following day couldn't get it to start. It's getting fuel to the carb, starter seems to be rolling ok, played with timing and check for spark, good and good. Ideas??
Old Sep 13, 2014 | 08:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DuraSpark Electronic Ignition was introduced in 1974, so if a 1968 has it, it was swapped in or it's an aftermarket conversion.
Old Sep 13, 2014 | 08:56 PM
orich's Avatar
orich
Check that the choke is working correctly.
orich
Old Sep 14, 2014 | 06:31 AM
Alex from GA's Avatar
Alex from GA
Things need to start and run are: compression-fuel at the right ratio-spark at the right time. Good luck.
Old Sep 14, 2014 | 10:51 AM
chromeLuxx's Avatar
chromeLuxx
Electro ign and choke
I installed the electronic ignition a few years back and have been pleased as punch I did. Never an issue and never a points job to be done.
Manual choke appears to be doing its job.
Trying to trace back all four elements and find the bug in the system.
Old Sep 14, 2014 | 12:22 PM
arctic y block's Avatar
arctic y block
How many miles on the engine. May well have jumped timing.
If ya got spark, fuel and compression but not in the right place
than that would be my guess.
Old Sep 15, 2014 | 11:21 PM
chromeLuxx's Avatar
chromeLuxx
So...did some poking around and couldn't find the timing mark with timing gun at first. Advanced the timing all the way and was finally able to see the marks get close, but still no start.
The truck ran and shut down fine, went to start and move it back a bit and that was it. No rough running, knocking, off timing, strange noises or etc., one minute good and the next it wouldn't start.
Old Sep 15, 2014 | 11:25 PM
chromeLuxx's Avatar
chromeLuxx
Update
Starter turns it just fine, spark to plugs, compression looks good and fuel to carb. Thinking maybe the Pertronix failure, timing chain and/or distributor.
Old Sep 15, 2014 | 11:47 PM
Tedster9's Avatar
Tedster9
If spark is at plugs, the Pertronix should be OK. Is it a good spark though - nice fat, bluish white, with a snap to it? A weak spark would prevent starting.
It is strange that the timing appears way off during crank? Earlier Ford dampers are prone to the outer ring slipping - not sure if later 360s have this problem - and would explain the timing strangeness if they are.
Old Sep 16, 2014 | 07:04 AM
Alex from GA
What Ted said about the damper maybe the cause( I remarked my damper). To check, remove #1 spark plug, turn the engine to get the piston to the top(with a long socket and a wood dowel in the hole), look at the damper. You can also check the timing chain by removing the valve cover and see if both valves, on #1, are closed.
Old Sep 16, 2014 | 08:44 AM
orich's Avatar
orich
Well now try by passing the Ign key switch run circuit.
This is done by Hot wiring it, make up a jumper wire attached to the +side of Battery going to the +side of coil terminal.
Then try to start with your ign. key switch. If it starts then check for bad ign. switch or it's plug.
No need to remove any other wires at the coil. Remember if it starts and runs to kill the motor remove Battery Hot wire.
Orich
Old Sep 16, 2014 | 09:27 AM
Tedster9's Avatar
Tedster9
Another thing to look at "truck sits a lot" and especially if outside, corrosion of electrical connections are something that always need servicing but particularly in the older rigs. Not saying this is the problem here, but it's easy to eliminate as a cause and even better, doesn't cost anything.
Old Sep 16, 2014 | 07:39 PM
sandman2102's Avatar
sandman2102
Had thesame problem a few years back. Traced it back to a loose connection at the coil.
Old Sep 17, 2014 | 10:46 AM
chromeLuxx's Avatar
chromeLuxx
Going to check all electrical connections again, make sure everything is good at the coil, and any issue there might be with the damper. Thanks
Friend recommended pulling up the distributor partially and moving it over one tooth to center the timing. Anyone ever heard of or tried this?
Old Sep 17, 2014 | 10:50 AM
chromeLuxx's Avatar
chromeLuxx
